Apple iPod touch Logo
Question about Apple iPod touch
MUsic not playing correctly on iPod Touch
When I listen to it with the headphones, the voices sound far away and the background music sounds different too,
Like sometimes only one instrument plays and it just sounds weird.
It works like normal when I hold down the area above the headphone jack, but that's very tiring...
It's still under warranty until December...
Would the Apple store replace it for free?
Posted by downheartedh on
Anonymous
    New Friend:
This problem is the same with me! i dropped my iPod, but it cracked the screen and i'm pretty sure i haven't dropped it on the jack because im very careful with it!!!
Posted on Feb 02, 2010
Jazz Boyce
  • 728 Answers
They should as long as they see no proof that it has been dropped near the headphone jack. And yes, it is a problem with the headphone jack.
Posted on Jul 01, 2009
Why does the people on iPod sound far away? When headphone are placed
Replace your headphones, if is still the same u have to replace phono input. Try to pull out headphones slightly when music playing, u should hear difference if not is the phono input.
tip
How to make the sound of the iPod Better
<p>Take your music with you on your iPod, portable media player from Apple. Depending on iPod model can hold between 500 to 40,000 songs. No matter how small or large your music collection, not content with mediocre sound quality while enjoying your music. Using a combination of hardware and software settings of the iPod add-ons to your iPod pump up the jam like never before. <br /> <p><br /> <p>1. Change the iPod music equalizer. These changes and increases the sound from the iPod to better match a specific style or genre of music. Press "Menu" on the front of Click Wheel iPod. Go to "Settings" and press the middle mouse wheel. Scroll down and select "EQ". Select the type of music you listen to (e.g. "Rock") and press the middle button of the Click Wheel. <br /> <p><br /> <p>2. Sound set control function for all your iPod music playing in the same volume as surprising increase or decrease in volume between songs. Click "Settings" from the main iPod menu and choose "Sound Check" to turn it off. <br /> <p><br /> <p>3. Use headphones instead of earphones that came with your iPod. While the earbuds feature enough for everyday use, audiophiles cannot enjoy the limited range of buttons compared with headphones bigger and more powerful. Additional benefits in some models of headphones, such as blocking noise canceling ambient noise, also can help improve your iPod listening experience. <br /> <p><br /> <p>4. Connect the iPod to a stereo amplifier or iPod compatible. This adds low-range and headsets that many cannot create and is ideal for cases where you connect your iPod to share with a group sounds like a party. <br />
on Aug 09, 2011 • Apple iPod touch
My ipod nano has songs but no sounds
Step 1:
Since entering the marketplace and revolutionizing the way people experienced personal audio, Apple's iPod has become the unquestioned leader in MP3 players. Available in several different models and versions including the original iPod, iPhone, iPod Nano and iPod Touch the iPod allows people to listen to any number of songs with just the click of the button. However, as is the case with numerous electronics, certain iPod users encounter issues with their device, particularly sound issues. These issues range from buzzing sounds through the headphones to low volume quality to no sound at all. Fortunately, there are ways to attempt to remedy these sound issues.
Volume and Song Selection Oftentimes, those iPod users listening to heavier music (such as rock or hip-hop) will encounter a buzzing noise when playing their device at maximum or near-maximum volume. Try lowering the volume a bit, as this will most likely remedy your buzzing issues. Also, try playing a different song from a different artist at the same volume to ensure sound quality is optimal across the board. Check the Headphones Before attempting to diagnose an iPod's sound issues, ensure the iPod itself (and not the headphones) are the culprit for these sound issues. Do so by disconnecting headphones from the iPod and playing them on another device, such as another iPod, a PC or laptop. If the quality is still not optimal, the headphones (not the iPod) are likely the reason for low sound quality. Also try connecting an iPod to an iPod listening dock. If the sound quality is optimal, but not so when connected to headphones, that would also indicate headphones as the cause of low sound quality. b> Reset the iPod Sometimes, simply resetting an electronic device such as an iPod, digital cable box or video game system will remedy the solution, as it gives the device a chance to reboot. Try resetting the iPod to remedy whatever sound problem you may be encountering, whether it's no sound or less-than-optimal sound. Not all iPods are reset the same way, so consult the user manual (either paper form or through Apple.com support) to learn how to reset a particular type of iPod. Adjust Sound Settings If sound quality is less than optimal, including too much bass, not enough bass, poor acoustics or any number of other issues, try altering an iPod's system settings to correct the issue. Do so by going to the "Settings" key on the main iPod menu, then going to "EQ." From there, test certain settings to see if they may correct the iPod's issue. EQ settings allow users to set their music to a certain type of genre (in terms of how the music is delivered), as well as lowering bass, increasing bass and altering acoustics. b> Make Sure Headphones Are Fully Connected As simple as it sounds, sometimes the reason iPods have no sound at all is because their headphones become somewhat detached from the device. Such is the case with physical activities such as exercising or doing yard work. If no sound comes through the iPod, make sure the headphones are plugged in all the way to ensure the lack of sound is not a simple oversight. Consult Apple Support Whatever the sound issue, if iPod users have tried everything possible to remedy the problem with no results, they can call Apple support or visit an Apple retailer to help further diagnose the issue. The issue could be a simple fix or might be so severe that purchasing a new iPod is the best course to travel.
So when I listen with my headphones now, they only play the background music (if that makes sense). The music is almost echo-y and sounds far away. I rarely get the main music/singer, and if I do hear...
leezamastre,
It sounds like this might be a setting on whichever MP3 player, or sound device that you are using. You should check for an "EQ" on your device and try setting it to a different setting to make it so you can hear the music and vocals of a song.
Please let me know if you have any other questions about this,
Cheers,
Garbanian
1helpful
Hi, I have Bose in-ear headphones and the sound is really bad on them since last night. It sounds like the music is really far away and without any base. I can only feintly hear the singer and one...
It sounds like you have a faulty connection between the headphones and the music device. Try fiddling with the port of your computer, iPod, or whatever else you use to listen to music. If the headphones do this on more than one device, it's a problem with them. Fiddle with the cord while you listen and see if you can target the bad area of the cord. If you can manage to listen to the headphones successfully while tweaking the cord, you might be able to use them still, if not they're probably blown or dead. Hope this helps =]
2answers
When I listen to music, only one of the headphones works. It gets really annoying when this happens because you have to keep messing with the headphones.
YELLWWORSE Bluetooth Headphones V4.1 Wireless Sports Stereo Earbuds with Mic, Noise Cancelling, IPX4 Sweatproof, 8 Hrs Playtime
  • More Comfortable, Safe and Secure Fit: Yellwwors sport Bluetooth features flexible ear hooks following the contours of your ears for a custom secure fit to prevent earphone from fall off accident.With Ergonomic design and light in weight, you will experience unprecedented comfortable sensation when you are running, jogging or exercising.It is the best for GYM
  • - More Professional Technology and Highest Standard Parameters: With Advanced Bluetooth v4.1, CVC 6.0 technology and apt-X tech, the headphone ensure bring you superior sound and amazing volume,it offers perfect enjoyment of music with powerful bass, super 3D stereo sound.
  • - More Convenient : Support voice-activated answer calls, voice prompts, battery indicator of your phone(only iphone and MI), Three-way calling function, Connect two phones at the same time
  • - Universal Compatibility: With V4.1 tech, Yellwwors headphones can work seamless with your favorite bluetooth devices, including iPhone, iPad, iPod Touch, Android Smartphones,tablets,Windows laptops, desktops, chrome Books,Bluetooth-enabled music players and more
  • - ULTRA-LONG PLAYTIME and EASY TO USE: Yellwwors Bluetooth headphones can deliver up to 8 hours of play time on a full charge.The design is more simple and practical
    Amazon com YELLWWORSE Bluetooth Headphones V4 1 Wireless Sports Stereo...
    My iPod sound doesn't work
    change bad capasitor and resistor near the headset plugin ...
    4helpful
    When i use the ipod touch speaker i can hear the music fine. when i use headphones i cant hear the voices very well and can only hear the background music. it's not my headphones because they work with...
    It sounds like it's definitely a problem with your iPod. . . Sometimes the connectors on the inside of the unit can go bad. I've not heard now this can be fixed though. I would try calling apple and seeing it the unit is still under warranty.
    3helpful
    3answers
    When I put my earbuds into my ipod touch only one side works
    i have the same problem. its not the headphones. its the itouch. its something to do with the jack-i think. because whenever i jiggle the plug eventually i can hear some of my music eventually. its a pain. and so how do i fix that ish?
    Top Apple Audio Players & Recorders Experts
    woodzowl307
    Marvin
    Marvin
    W.L.
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
