errorcodepanasonic.blogspot.com/.../error-codes-for-panasonic-copiers.h...Jul 17, 2011 - Error Codes for Panasonic Copiers problems solusions help ... J40-42, Fuser exit jam ... dp 8060 code e-501 plz tell the solution what can i do ... I need a help with my Panasonic DP8045 printer. ... DP 6010 DP 6020 G DP 6020 H DP 6030 DP 6030 G DP 6030 H DP 6530 DP 7000 DP 7240 DP 8016 P DP ...
www.icd10data.com/ICD10CM/Codes/J00-J99/J40-J47/J40- Home > 2015/16 ICD-10-CM Diagnosis Codes > Disability of the respiratory system J00-J99 > Chronic ... Bronchitis, not specified as acute or chronic J40-
J00 is an unidentified jam. Means that a paper jammed in the machine and the user switched the machine off and then on again. So the machine lost the ability to inform the user where the jam is. As a result the user has to find out where the jammed paper or piece of paper is.
Means that it never fed the paper from the cassette.Sugest that you ensure that the paperr is loaded correctly and that the cassette is correctly adjusted.May need the feed rollers cleaned.
Code J00 is paper tractions error, either one of the traction wheel or one of the sensor is stuck or defective, often you need to take apart the printer to fix this.
jam 0 means there is one of your switches not working good, it shows that there is jamming but there is no paper, so u have to check which switch is not in right place and fix it.
