When washing dark color clothing, especially black ones, there's always some kind of white dust, not lint, left on the black color garments. This is very annoying because every time after washing them, I have to hand rinse or to wipe them off with a damp cloth. The manual mentioned it may be not enough water. But how can I tell there's enough water in the machine or not. There's no water level for me to set nor I can see how much water in it once the door is closed and locked. Please tell me how to solve this problem.
The white residue you can see is undissolved soap powder, You need to first try reducing the quantity of powder you are using, there is also a good chance that the machine has built up residue between the inner and outer drum, I'd suggest buying a washing machine cleaner and running it through the machine following the instructions on the packaging, A hot empty wash with a cup of dishwasher powder and once it fills up pausing it to soak for a while will also do the same if you cannot find a washing machine cleaner.
SOURCE: Samsung Front Load washer has odour
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
SOURCE: samsung washing machine smells
the LE error code is an over suds error.
the smell could be coming from lint and foreign object matter collected in the rubber bellows that is conected to the drain pump this should be cleaned out i hope this helps
SOURCE: The smell that comes from this machine is
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Hope your filter is clean. Don’t wait for the machine to jam to
look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such
things can be stuck around the inside tub of your washer. Try this product, it
works great on all front loaders. Use very hot water with the Affresh pellet
with no clothes and run the machine through a cycle. Also helps with any
stagnant water smells. Put the Affresh
pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help,
can't you. Thanks.
SOURCE: I have a samsung wf316law\xaa
hello,
solution bellow.
There is disclosed a method of controlling an automatic door
opening/closing apparatus
for a washing machine that includes the steps
of determining whether or not there is an error in
an automatic door
opening or closing operation carried out in response to a command to
open or
close the washing machine's door; determining if the erroneous
operation has been
repeated more than a predetermined number of times
according to consecutive incoming commands to open or close the door;
and when erroneous operation has repeated more than the predetermined
number of times, ignoring a subsequent command to open or close the
door.
1. A method of controlling an automatic door opening/closing apparatus
for a washing machine door, the method comprising the steps of:
determining whether or not there is an error in an automatic door
opening or closing operation which operation is carried out in response
to a command to open or close the washing machine door;
determining if the erroneous operation is repeated more than a
predetermined number of times according to consecutive incoming
commands to open or close the washing machine door; and
in the
event that the erroneous operation is repeated more than the
predetermined number of times, ignoring a subsequent command to open or
close the washing machine door.
2. A method as set forth in claim 1, further comprising the step of: returning the door to the washing machine to an original position in the event that the error occurs.
3. A method as set forth in claim 1, wherein the step of determining if
there is an error in an automatic door opening or closing operation is
performed on the basis of whether or not an inversion occurs in an
open/closed state of the door within a prescribed period of time after
an automatic door opening or closing operation is initiated.
4. A method as set forth in claim 1, further comprising the step of:
clearing the number of errors in the case where the door of the washing
machine has been opened or closed manually at the time of occurrence of
the errors.
5. A method as set forth in claim 1, wherein said predetermined number is 3.
6. A method for controlling the operation of an automatic door
mechanism in a washing machine, said method comprising the steps of: sensing a command to automatically open or close a washing machine door;
sensing whether a failure occurs in opening or closing the door in
response to the command to automatically open or close the door;
incrementing a counter indicating the failure;
determining whether the counter is equal to a predetermined number; and
failing to engage the automatic door mechanism in response to a
subsequent a command to automatically open or close the door if the
counter exceeds the predetermined number.
7. The method claimed in claim 6, further comprising the step of: returning the door to an original position if a failure is detected.
8. The method claimed in claim 6, wherein failure is indicated by a
lack of a transition between a door open state and a door closed state
within a predetermined time period following entry of the command to
automatically open or close the door.
9. The method claimed in claim 6, further comprising the step of: clearing the counter if the door is opened or closed manually following a failure indication.
Thanks for using fixya.
SOURCE: My front loading Samsung washing
run the unit with no clothes in once it has stopped check the water level. in the rear of the tub the water hould be 3 1/2 inches deep and 14 inches wide.and will taper off towards the front of the drum.
