SOURCE: Boston BA745 speakers bought. how to install drivers or whatnot on XP
Mine dont work my pc wont recognize them. they were previously installed and now the driver isnt recognized. how do i fix it? do i download something?
SOURCE: I have no sound
Yes you must have the correct drivers installed. If you formatted your drive, you will most probably have to download all motherboard drivers also
SOURCE: How do I plug my BA745 Boston speakers into a MAC
I have the same speakers. It should have two plugs, one green and one pink. the pink plug is for a microphone. On the side of the speaker with the control knobs, you will find a headphone jack and a microphone jack. Unless you plan to plug a microphone into the pink microphone jack on the side of the speaker, you don't need to plug in the pink plug that goes to the PC. This is basically a microphone extension cord that runs through the speaker cord. That's all the pink plug is for. The green plug, on the other hand, is for your audio out. take the green plug and plug it into your computer's head phone outlet and you're good to go. You can use the speakers with any device that has a headphone jack. Just make sure you use the green plug, not the pink plug.
SOURCE: Can I connect my old Boston BA745 speakers (with
Yes, you can connect your 2 satelites at the headphone jack using an adaptor like this (I assume that the connector at each speaker is RCA). The problem is that you will get very low volume, even when you are all the way up at the settings. This is because these speakers don't have amplifier. Their amplifier was in the 3rd speaker, the subwoofer. So I don't think that the result will be exactly what you need.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
