Question about Konica Minolta Office Equipment & Supplies
Bizhub C203 just takes itself offline
Works fine in the early day and disconnects from our network after an hour or so of running. This occurred after a power outage. Unit is connected to a battery back up an surge protection device
Norman J Weimar Jr
  • Konica Minolta Master
  • 6,960 Answers
Have you try a different battery back up and surge protector there is stll a possibllity it did get damage any how.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 24, 2016
5 Related Answers
Anonymous
  • 214 Answers
SOURCE: Won't print over network
if same thing happened with c450, then i guess, that the problem is in the network. does the printer answere a ping, also you can ping from printer to network. maybe youll find something. but last option is that you have to upgrade firmware or change network board, also check network settings from printer.
Posted on May 11, 2008
jmassengill
Johnny Massengill
  • 345 Answers
SOURCE: Bizhub C350 - Print spooler not running after power outage
I would print out a copy of the network configuation of that printer and ensure it has the proper network settings (I.E. IP address, Subnet mask and Default Gateway. I just worked on a printer that I accidently pull the plug on and it lost it's network settings and wouldn't print until I changed them back to the correct settings.
Good luck
Posted on Nov 11, 2008
Anonymous
  • 5 Answers
SOURCE: After a power surge it comes up with a C0501 malfunction code and shuts itself down
Turn ON the Power Switch with the Stop key held down. This also works on bizhub 162
Posted on Aug 10, 2009
Adorjani Laszlo
  • 1316 Answers
SOURCE: Minolta Bizhub C253 - C-11C3 finisher error
The 11XX code refer to the printer and hard .To reset push the reset button or open the front door and close.
Posted on Dec 11, 2009
MSM
  • 165 Answers
SOURCE: Konica Minolta Bizhub c203 printer
where do u scan e mail or folder? if e mail your smtp server ip may have been deleted/changed if folder the path may have changed/deleted or password changed on the server/desktop
Posted on Apr 05, 2010
Please how can I clear the memory on my printer (Konica Minolta bizhub C203 coloured printer)
Go to service mode
utility-counter-stop-00-stop01
go to system 2/ or 1
select initialization.
select all data.
press start button
restart from main power.
Re-configure all network setting for printing/scanning
Nov 29, 2016 | Konica Minolta Bizhub c203 Copier
Konica minolta bizhub c203 blue data light blink copier not working
Have you cleared all the print jobs currently in the que and on the control panel. also disconnect your network cable power off the machine then on will it copy not print? data light blinking mean job is trying to run is the paper draw or by pass tray have paper an in the correct orientation landscape or portriat
Jan 24, 2016 | Konica Minolta Office Equipment & Supplies
Konica minolta c203 firmwere problems
http://gethuman.com/phone-number/Konica-Minolta
Phone Number 800-456-5664
Talk to a Human
Press 0 OR Press 1, then 3 and then 1 then wait for the prompts
Average Wait: 8 mins - 24 hours, 7 days
Jun 04, 2015 | Konica Minolta Bizhub C203
Machine showing error D370
when machine waqs working atonce power failure occurred and after that it showed error D370
Oct 26, 2012 | Konica Minolta Bizhub C 353, Bizhub...
Copier says offline
reboot and check your ip address and cables. aslo see if you can ping the copier..
Jul 26, 2011 | Konica Minolta Bizhub c203 Copier
Hi, I have a Bizhub C203 and the scanner does not seem to work since we lost our network yesterday. Network is now up and running but I don't know how to tell the scan function that!
hmmmm either your scan file was lost or changed to a new location or your email has changed or needs authentication... there are a bunch of different things that can make that happen, can you print to it??
Apr 14, 2011 | Konica Minolta Bizhub c203 Copier
The print margins on my Konica Minolta Bizhub c203 cut off the bottom of my pages. how can I fix this?
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
May 20, 2010 | Konica Minolta Bizhub c203 Copier
Konica Minolta Bizhub c203 printer will print from all computers in our network, but has stopped scanning
Apr 05, 2010 | Konica Minolta Bizhub c203 Copier
116 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
