Pinnacle Dazzle DVD Recorder Logo
Posted on Mar 10, 2017
Dvd plays but music skips in playback on my TV.
I did a Potostory, saved it as a Mdia Payer file and imported it into Moviemaker. I then saved it to my video camera (DV output in Movie Maker) and burned it from the video camera through the dazzle video recorder. Photostory has no way to burn to a DVD, and I want to be able to show the presentation on a tv through the DVD player. It was a very complex process and the first result came out well. It played on the TV using the DVD player and although the music wasn't as nice as on the computer it worked well enough. I saw some correction that needed to be made, so did the whole process again and this time ended up with good images, but the music skips. I burned a copy onto another DVD to give to the person I am making the opresentation for and it also skips so I don't think that it is the DVD. What have I done wrong, I am very illiterate when it comes to tehnical terms, so I need it in plain English. Thanks
JT
5 Related Answers
Anonymous
  • 27 Answers
  • Posted on Mar 05, 2009
SOURCE: After burning the DVD the Video Speed is Fast
please try to update the driver of your video card and sound card. Please try also to update the version of your directX to version 10. make sure that in the step number 4 in the program select the video quality to best not automatic
Anonymous
  • 6 Answers
  • Posted on Mar 15, 2009
SOURCE: Dazzle video creator 80, good video, but no sound input
hi lsiemon,,
 u jus need to open these files in VLC media player, its an universal player and can recogonise any formats,. try to open' tis way,,. Thank You,,.
Anonymous
  • 104 Answers
  • Posted on Mar 24, 2009
SOURCE: When I burn a VHS
Advice to all of you, burn on the slowest possible speed, try 1X for a dvd drive , 4x for a cd drive. and please be patient , it can take long.
Anonymous
  • 21 Answers
  • Posted on Apr 12, 2009
SOURCE: no audio when using "dazzle" dvd recorder
http://www.pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Dazzle/Dazzle+Video+Archiving/Dazzle+DVD+Recorder.htm?view=knowledgebase
Try looking here start there and maybe it will help you out
Anonymous
  • 50 Answers
  • Posted on Apr 29, 2009
SOURCE: recorded dvd will not play on dvd player after dazzel put on dvd
At this case there might some applications or programs that use the dvd burner. I mean ( nero, roxio or others)
If you don't mind you can try the steps below to isolate the case.
Answer Title: How do I turn off background programs that are interfering with system performance and software installation?
Answer Link: http://pinnacle.custhelp.com/cgi-bin/pinnacle.cfg/php/enduser/std_adp.php?p_faqid=9814&p_created=1082135512
Then try it again.
If the problem occurs try to update the firmware of your dvd burner.
2answers
Annoying crackling whilst playing audio.
Try VLC media player. Or a different one than what you have now
2helpful
How do you get your 6700 to play music etc on the headphones
Your phone includes a media player for listening to songs and viewing video clips. Music and video files stored in the music folder in the phone memory or on the memory card are automatically detected and added to the music library.
To open the media player, select Menu > Media > Media player.
Music menu Access your music and video files stored in the phone memory or on the memory card, download music or video clips from the web, or view compatible video streams from a network server (network service).To listen to music or play a video clip, select a file from the available folders and Play.
To download files from the web, select Options > Downloads and a download site.
To update the music library after you have added files, select Options > Update library.
Play songs
To adjust the volume level, press the volume keys.
Operate the player with the virtual keys on the display.
To skip to the beginning of the previous song, select icon_28.giftwice.
To rewind the current song, select and hold icon_28.gif. Release the key at the position you want to continue the music playback.
To close the media player menu, and to continue music playback in the background, press the end key.
To stop the media player, press and hold the end key.
Hope it helped.
When I try to play data disk I get file then directory Root how to I get out of that
A regular DVD player doesn't support playback of a data disc. It can only be used to play audio and video discs.
Furthermore, a DVD player that supports playback of Divx can only play a data disc that has any movie of music files on it.
3answers
DC 220 video file freezes in VLC player
Installed open source software mediacoder to convert my .VOB file into MP4. It is playing perfectly in VLC player now
Dvd created inn sonic mydvd will only play once
It most likely has something to do with the way set top players store certain things in memory. have you ever noticed that if you pop a dvd out while watching then put it right back it, that it will resume? try putting another dvd in then putting the picture dvd in and see what happens.
2helpful
6answers
Lost instruction
ok lamar230990 to turn your mp3 player to msc mode disconnect it from the computer and turn it on. once it is on go to settings and scroll down to protocol and click on it with the play/pause button. this should turn it to msc mode then connect back in to the computer and go to this site to download the software www.rcaaudiovideo.com
Playback
saving .jpg/.JPEG/ .BMP file to a dvd disc don't wrie properly. try using a CD-R disc and save pctures as .jpg.
Dvd burn erros
hi yar i m kishore frm andhra predesh ,india
adobe premier rpro is better then vista movie maker
there is no problem in making videos.
we can give more effects in that.k try it.
ur's kishore chowdary.
else save the video file into hard disk then write into dvd by using
nero,alchol etc
ur's kishorechowdary
+919441133420
Top Pinnacle Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
