Unfortunately, folding it to store is not a simple task. You'll have to remove the base which will allow you to fold the legs. Although the article I'm referring you to is for converting the exersaucer into a stage 3 activity table, it does give instructions on how to remove the base which will allow the legs to fold. How to Convert the Evenflo Exersaucer into Stage 3
SOURCE: I need assembly directions for evenflo exersaucer triple fun.
1. Remove toys and seat from the exersaucer.
2. Fold exersaucer, but do not let the tray lock to the base. With
exersaucer flat on the floor, twist each leg assembly (B) fully
clockwise until it stops. Fully depress one of the pedestal locking
tabs (C) then push on the leg assembly (B); leg will partially fold.
Repeat this for all four legs. After pressing the fourth pedestal
locking tab (C), the Exersaucer will fold with the tray (D) rotating
toward the base (E). Make sure all four tray locks. (F) are locked onto
the base before trying to carry exersaucer.
3. Place your fingers beneath the legs (A) push upward to disconnect
the leg assemblies from the pedestals (B). Repeat for all 4 leg
assemblies.
4. After all four legs have been disconnected from the pedestals, remove tray assembly (C) from the base (D).
5. Turn tray (C) upside down and remove both end caps (E) from beneath.
6. Squeeze both locking tabs (F) on each side of the tray to disconnect
and seperate the tray halves (C). 7. Connect tray halves (C) to form
activity table.
7. Connect tray halves (C) to form activity table.
8. Rotate leg assemblies (A) fully clockwise until they lock into
postition. Make sure all four legs lock (G) are locked properly into
the uper leg pedestal (H). Also make sure all four leg locks (I) are
sticking out past the edge of the tray.
9. Turn table over and install two end caps (E). Make sure both end
caps lock into place. NOTE: one end cap installs from above and the
other installs from below.
10. Install toys on activity table. If desired, adjust table to the
appropriate height for your child. IMPORTANT: NEVER use stage 3 without
end caps!
SOURCE: how to remove the seat cover on exersaucer
Hi, all the way around it are plastic bits sticking out and the seat cover is clipped onto the plastic bits, just lift them off one by one, all the way around. then when your done clip them back in again. hope this helps.
SOURCE: need a replacement seat for a evenflo mega
Contact Evenflo. Every time I did, they replaced the necessary part. It was a few years ago, but they were great then. Just give the website a try http://www.evenflo.com/category.aspx?id=19&fid=277
SOURCE: I need to know how to fold the Evenflo smart steps
You can go to this link http://www.evenflo.com/category.aspx?id=19 or just call the customer support number at
US: 1-800-233-5921
Canada: 1-937-773-3971
Hours of Operation
Monday - Friday
8:00 a.m. – 5:00 p.m.
Eastern Standard Time
