If that fails, they require a tune up or service. Perhaps antenna replacement, batteyr replacement, etc. You cannot adjust the power output, it is performed by radio programming software by an approved service facility.
Check your antennas, use the standard antenna for best range. Also check your programming to be certain you are programmed to match one another identically, and the radio is set to high power. Check your batteries to make certain they are not bad or low. And lastly, hold your radio upright, perpendicular to the ground when transmitting for best range.
