Question about LaCie Computers & Internet
I cant see my files on my tv from the lacie premier hd
I have an older lacie premier hd and when i plug it into the tv, i see the blue screen, the options and all seems fine but i cannot see any files on the tv..ive tried multiple types of movie files...could it be that something is missing from the hd itself?some start up files? thnks!
5 Related Answers
micromaster
micromaster
  • 3614 Answers
SOURCE: error copying file or folder
One of the most important yet overlooked elements of PC maintenance is data backup. If you do not perform regular backups, chances are your productivity will eventually suffer from data losses or a failed Windows installation.
All versions of Windows after 3.1 ship with a free backup utility called Microsoft Backup. It is not the best backup program available, but it may be sufficient for your needs. (Backup is better in later versions of Windows. Microsoft recommends Win98/Me users purchase a third-party utility.) If you want more control over your backups, consider purchasing a third-party program.
Backup is part of the System Tools utility. However, Setup does not install it by default in Win98/Me/XP Home. If you cannot locate Backup, visit the Microsoft support site and query for article No. 152561 (Win98), No. 264541 (WinMe), or No. 302894 (WinXP Home).
In Win98/Me, click Start, select Programs, Accessories, System Tools, and click Backup. To create and run a backup, click the Create A New Backup Job radio button and click OK. Follow the prompts to create a full or partial backup. If you want to create a backup set and run it later or run an existing backup set, open Backup and click the Open An Existing Backup Job radio button and click OK. You can now access the main Backup dialog box.
In Win2000/XP, navigate to the System Tools utility and select Backup. Click the Backup Wizard button. If you do not see a Backup Wizard button, click the Welcome tab. In WinXP, the wizard will start automatically if you are in wizard mode. Follow the prompts to create your backup set.
When you reach the last dialog box, Completing The Backup Wizard, you can click the Advanced button to create a backup schedule (this option is not available in Win98/Me). When you reach the When To Back Up dialog box, select the Later radio button and click the Set Schedule button. Perform data backups on a schedule that is appropriate to the importance of your files (once a week is a common timeframe). You should also perform a system backup at least once a month.
If you do not want to use the wizard, or you are working with an existing backup, open Backup and click the Backup tab to access the main Backup dialog box.
Posted on Feb 11, 2008
Anonymous
SOURCE: LaCie d2 Quadra 500 GB HD dropped, now makes strange chime/alarm
Modern hard drive motors can easily become seized after an impact. The only DIY solution I am aware of is the use of a heat gun over the back of the drive motor. The build up of heat within the motor is sometimes enough to free it.
If the drive was running the problem may be due to a phenomenon known as "sticktion" where the drive head is actually stuck to the disc surface. If this is true then you need a data recovery company.
Posted on Nov 28, 2008
Anonymous
  • 10 Answers
SOURCE: ps3 does not reconize FAT32 partition on external hd
download this program http://www.compuapps.com/Download/swissknife/swissknife.htm
and format it again then try it, it should work fine, did for me.
Posted on May 31, 2009
Anonymous
  • 4 Answers
SOURCE: my lacie hard disk 1tb all of a sudden isnt
Just contact www.lacie.com great support. their answer for my drive was to reboot the drive. For me it worked.
Follow the procedure below to reset the Network Space to factory defaults:
  1. Move the power switch to the OFF position. Wait for the drive to shut down.
  2. Turn ON the drive.
  3. Within about 3 seconds, flip the switch OFF and On several times.
  4. Immediately turn it ON
If the light flashes quickly, the unit is resetting itself. Attempt to connect to the drive again after about 1 minute using the default username and password (by default, they are both admin.)
Posted on Feb 04, 2010
Anonymous
  • 80 Answers
SOURCE: My Lacie isn't letting me
did you use your drive with a PC too?
What you describe is commonly linked to a drive formatted as NTFS (a windows partition format) which is read only on a plain MAC system. There are add ons you can install on your MAC to make NTFS writable. I can direct you to one if you need.
Another possibility is that your drive is formatted as MS-Dos (FAT32) which is read and write enabled for both PC and MAC, but it has the negative aspect of limiting file size to 4GB. So in your case, maybe your movie files are larger then 4GB and your drive is formatted Fat 32.
To verify the format of the drive, go to DIsk utility, select the LaCie drive and read the information that shows at the bottom of the Disk Utility window.
Regards,
Posted on Jan 12, 2011
Lacie 324 screen turned blue
yeah mine too ... was working fine then came up Blue screen. switched back to another laCie 324 monitor happen to have. Called LaCie who said they only replace these as it is cost prohibitive to repair or service... oh and I had it 18 months and they wanted me to pay for a new one and after I send it back if it is not working and is covered under warranty they will reimburse ... what kind of customer no service is that.
Jan 10, 2013 | LaCie 324 LCD TV
Lacie playhd system folder corrupt
sounds to me(pun intended) that the driver for HD TV is corrupt of missing what is hd unit you have and what pc are you using
May 22, 2012 | LaCie 2TB LaCinema PlayHD Media Player...
Doesn't work
am not so sure if this is a similar issue with iomega2_bing.gif external drive in which the drive wont show up on My Computer but when the external drive was plugged into an ubuntu machine the drive was being detected and working just fine.
Please try to do the same. plug your external drive to an ubuntu machine and lets see if it can be detected. If it is then the hard disk has a similar issue with iomega drives. check this link for the solution.
Apr 05, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Lacie Lacinema Premier does not start anymore. The light is on but the window won't open, so I can't access any of my docs or install any update of the firmware. Same happens when I connect it to my tv: it...
Check the memory. It might be missing, or it might be full.
There might be something wrong with your MP3 player. Test it a few times , and if it doesn't work, you might need a new one, Or you can exchange it with another new one.
Mar 31, 2010 | LaCie LaCinema Premier 301814U MP3 Player
LaCie drive won't turn on (blue light doesn't go on)
I doubt your hard drive is dead, even if your HD was dead the blue light would go one. It has to be the internal controller.. Your best bet is to get a HD enclosure and put your old drive in there. I've burned through 3 Lacie cases, all with similar problems..
Ciza
Sep 27, 2008 | LaCie (300770) 250 GB Hard Drive
Lacie silverscreen
did these movies come from licensed sources, by chance? You may be running into a simple issue of licenses not transfering from your HD/computer to the storage unit.
Mar 17, 2008 | LaCie Silverscreen 80GB USB 2.0 - Portable...
File transfer size limitation for LACIE HD
hi
can i suggest that you use winrar to divide the file size of your file that you want to transfer to your lacie. this might work.
download winrar @ majorgeeks.com
but if you LACIE still says that it does not have any disk space left...i would suggest that you reformat the HD instead. but make that a last resort...
hope this helps
Jan 21, 2008 | LaCie Design by F. A. Porsche 160 GB Hard...
Lacie d2 HD Quadra 250gb
Lacie D2 drives in my experience are infamous for not having the most durable bridge boards. The bridge board is a chip that has a chipset on it which take the SATA or PATA connection and send it to the USB and or Firewire ports on the enclosure. If the drive is powered up, you should get a blue light on the front. When connected to either mac or pc ( porsches are MS_DOS formatted out the box ), if it does not mount or does not appear in DISK UTILTY, then it is a high probability that the enclosure/bridge board has failed and the drive ( if not making grinding, buzzing, clicking or beeping sounds) will have to be extracted and placed into a more stable enclosure.
Hope this helps.
Dec 01, 2007 | LaCie (300770) 250 GB Hard Drive
Computers & Internet Logo
Top LaCie Computers & Internet Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
