Question about Sony Handycam DCR-TRV280 Digital Camcorder
Play and other buttons are not working
Everything has been working fine and just now as I am reviewing tapes, the play, Rew, FF, and stop buttons will not work.
5 Related Answers
Anonymous
  • 45 Answers
SOURCE: Sony DCR TRV70 - Tapes won't play
the head may be dirty, clean it by using a cleaning cassete, maybe its playing but can not produce a clear picture, not able to produce a clear picture would automatically change the display to blue.
Posted on May 20, 2007
Anonymous
  • 73 Answers
SOURCE: Camera control buttons do not work, stop, play etc
your flexible control panel cable may have torn ( from loading and unloading ) - if there are leds ? in yours , the replacement part often does not have them ( many users miss them ) ; get an estimate , before committing to repairs on a 7 year old camera ( starts at $ 50 plus parts and shipping , here in puerto rico ) ;
Posted on Aug 16, 2007
Anonymous
  • 169 Answers
SOURCE: My Touch Screen Buttons
the flexwire is the problem of your camera and if all wiring be cut the next problem is the lcd monitor would not turn on...go to a service center for replacing or repairing the flexwire...
Posted on Sep 01, 2007
Anonymous
  • 254 Answers
SOURCE: VCR stops playing
A couple of possibilities: the bad electronics unit might have power supply problems, optical sensor problems, or other problems with the electronics. If you have some tech savvy and a voltmeter, you could check the power supply voltages. This circuit is likely in the close vicinity of the fuse. On the output side you should see a +5 volt, +12 to 15 volt, and perhaps a -35 volt (approx). The +5 supplies the logic circuit, +12 the motors. If these voltages are missing, or way out of tolerance, you will have a dead unit. A frequent cause of problems in the supply is bad electrolytic capacitors, especially in the older units (Panasonic manufactured rigs, late '80s/early '90s). Possible values on these capacitors: 2200MFD/10V 1000MFD/16V and several others. Replacements can be supplied by MCM electronics, Mouser electronics. I use the Panansonic FC series from Digi-Key Electronics. Sensor problems: Many VCRs have the sensor opticals mounted on the main circuit board, and locate themselves in particular spots in the mechanical section. One or more sensors detect tape loaded, one each for the supply & takeup spindles. If any of these sensors (especially the supply/takeup sensors) are non-working, the logic circuit will detect an error condition, and shut down the unit or at least put it into a stop mode.
Posted on Oct 02, 2007
Anonymous
SOURCE: Cassette Tape stuck
How does one take the cover off?
Posted on Feb 02, 2008
Sony tc k670
Take out the tape and press play, do the wheels move? if not the motor has burnt out, the tapes may have been sticky. Hold a tape and wind the wheels with your finger, are they difficult to move?
Dec 21, 2013 | Audio Players & Recorders
The DVD works fine but the VCR doesn't play, rewind or forward tape.
l would have a look inside to see if when a tape is inserted it loads and will ff and rew, if the transport that moves the tape has failed it will account for what is happening.
Aug 27, 2012 | Zenith XBV442 DVD Player/VCR
I dropped my DCRTRV250. It landed on the lense/cover corner. Since then I can not play or get a video picture, just a blue screen. I can hear and feel the motor turning the video tape. In fact all the...
am sorry for you,but probably you will have to go for a qualified tech for this problem i got a idea about what hapen inside the camera when she land down
your ccd as been damage and its come whit the lens ***'y ,that an hours jobs about to fix that
and dont try to do it your self its verry touchy.
Feb 25, 2010 | Video Cameras
I push play and it stops after 2 seconds, same with rew, and fwd
Is the tape actually moving when you initiate transport commands? Most machines are smart enough to know something isn't moving when it should be. That it fails in BOTH FF and REW suggests the reels aren't moving to take up slack. Cheap machines use glorified rubber bands as drive belts for the reels. Without specifics re: make/model we can't get too precise with an answer. I'd have a pro look at it.
Feb 15, 2010 | Audio Players & Recorders
I have a Sylvania NB501SL9 blu ray player with no remote. i have dish remote and programmed it for the blu ray , the play ,stop and ff/rew. works fine, but i can't get the arrows to work, therefore i cant...
went ont and plunked down 14$ for a new universal remote. could not get the dish remote to do anything other than stop ,play,ff and rew. which just isnt good enough if you want to browse the blu-ray disk @ all !! so gud luk to all. and Merry Christmas !!!
Dec 01, 2008 | Sylvania NB501SL9 Blu-Ray Player
I LOST THE MANUAL. CAN'T FIGURE OUT HOW TO ERASE PERVIOUSLY RECORDINGS.
How are files erased from the VN-3100PC?
Individual selected files or the entire contents of a selected folder can be erased from the VN-3100PC.
To erase a selected file:
  1. Press the [REW]or [FF] button to select the file.
  2. Press the [ERASE] button.
  3. Press the [REW] or [FF] button to select YES.
  4. Press the [PLAY] button.
To erase the contents of a folder:
  1. Press the [REW] or [FF] button to select the folder.
  2. Press the [ERASE] button twice.
Erased files cannot be retrieved.
hope this helps! =]
thanks for using fix ya
Aug 01, 2008 | Olympus VN-3100PC Digital Voice Recorder
NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Dec 06, 2007 | Audio Players & Recorders
Used a wet VHS cleaner and now my VCR doesn't work right. Help!!
The VHS cleaning cassette possibly deposited fiber in the heads in the drum. You may need to open the cabin and examine the heads and the mechanism for foreign matterial.
Feb 02, 2007 | Proscan PSVR72 VHS VCR
Sony Handycam DCR-TRV280 Digital Camcorder Logo
Top Sony Video Cameras Experts
Jax Planet
Jax Planet
Nasir Muhammad
Nasir Muhammad
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
