Chevrolet 1996 Chevrolet Blazer S10/jimmy S15 Radio Logo
A
Anonymous Posted on Feb 05, 2014
ERROR CODE P1351 - Chevrolet 1996 Chevrolet Blazer S10/jimmy S15 Radio
2answers
BMW X5. What is a P1351 code please?
Question edited for clarity.
Question moved to model category.
Code : P1351
Make : BMW
Description : P1351 BMW Misfire Cylinder 5 With Fuel Cut-Off
Possible causes :
- Faulty Spark Plug
- Faulty Ignition Coil
- Intake vacuum leak
- Faulty Camshaft Position Sensor
- Ignition Coil harness is open or shorted
- Ignition Coil circuit poor electrical connection
https://www.cardiag.me/en/obd2-en/p1351-bmw-2/
More here
https://www.google.com/search?q=BMW+X5.+What+is+a+P1351
2answers
Error code P1351 is in my book of codes
Error Code P1351 is defined as Variable Valve Timing Sensor Range/Performance Problem Bank 2. This error code is a manufacturer-specific trouble code, meaning it does not apply to all vehicles makes. ... Specification of the definition, troubleshooting, and repairs still vary from one make and model to another. Probably need to check with your dealer if the code applies to your car.
I have a Peugeot 407 error codes p1447 and p1351 are coming up anyone know
P1447 ELC system closure valve Flow fault
EDC15C2- PEF filter pierced or differential pressure incorrect.
P1351 IDM input circuit Malfunction/Ignition coil control circuit High voltage
SID 803 - Pre/Post heating relay circuit. Relay not controlled and glow plugs supplied.
save this,it is codes for your peugot,,https://www.mavericktechnology.co.uk/technical/peugeot-citroen-psa-specific-dtc-fault-codes
1helpful
2answers
What does code P1351 mean?
until you fix the fault the code will come back
code p1351 is cylinder misfire with fuel cut off--cylinder 5==causes --wiring connections--fuel level low---ignition/fuel system---intake leak--mechanical fault
I think my car imobilser is not working. I get the following errors when I attach the diagnostic machine 1. egr circuit low 2. Fueld Sensor temp high 3. P1351 code Any help please
Why would you think you have a immobilizer problem ? Doesn't the vehicle start ? Is there a security light lit on the instrument cluster ? What make vehicle ? What diagnostic machine ? Your P1351 is a manufacturer specific code ! http://www.obd-codes.com/p1351
Code p1351
GM General Motors P1351: ICM Circuit High Input Conditions Details: With engine speed less than 250 rpm, ignition control enabled, the VCM detected that the ignition control circuit was more than 4.90 V
Read more at: https://www.obd-codes.com/p1351
Copyright OBD-Codes.com
Engine light comes on twice at startup and stays off while riding check codes they are p1351 and p1354 is this a serious problem?
P1351 = ignition coil open/low
P1354 = ignition coil open/low
Both codes have the same error message (why? dunno)
19helpful
2answers
Computer analysis showed these codes... P0330 P1133 P1135 P1346 P1349 P1351 P1354. can anyone tell me what each of these mean?
P0330 Knock Sensor 2 Circuit (Bank 2)
P1133 Air/Fuel Ratio Sensor Circuit Response Malfunction (Bank 1, Sensor 1)
P1135 Air/Fuel Ratio Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
P1346 VVT Sensor Range/Performance Problem (Bank 1)
P1349 VVT System Malfunction (Bank 1)
P1351 Variable Valve Timing / CMP Sensor Range / Performance
P1354 Variable Valve Timing System Fault
NOTE:Variable Valve Timing (VVT) sensor is also known as camshaft position sensor.
The Variable Valve Timing (VVT) system controls intake valve timing in response to driving conditions.
Possible causes are:
  1. Incorrect valve timing P1346, P1349, P1351 & P1354
  2. Faulty oil control valve P1346, P1349, P1351 & P1354
  3. Faulty VVT controller assembly P1346, P1349, P1351 & P1354
  4. Faulty ECM All Codes
  5. Jumped timing belt All Codes
  6. Faulty Camshaft Position Sensor P1346, P1349, P1351 & P1354
  7. Faulty O2 Sensor (Bank 1, Sensor 1) P1133 & P1135
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Top Chevrolet Audio Players & Recorders Experts
Arnie Burke
Arnie Burke
Stan Ford
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
