Question about Mag Innovision Computers & Internet
Display error message
Blue message appears in the upper left corner. SH770 P7002Q. Qdi. QD17EL07 What to do to remove it?
5 Related Answers
Anonymous
SOURCE: Mag Innovision LT776s 17 in. Flat Panel LCD
I have the same problem except it usually happens after Ive left my computer idle for a while... i.e . Overnight, I usually turn off the monitor and I hit the button after I come back to turn it on. I get the same flashing light for several minutes. This has been a problem for several months, but only recenly have i gotten the same error message you mentioned. Each time ive booted the computer up cold or restarted it has worked fine but this time it took longer along with displaying the message: Top Left to Right: SH770 P001 Bottom Left to Right: AU M170EN05 Anyone else who can clear this up?
Posted on Apr 12, 2007
jerryg50
Jerry Greenberg
  • 1691 Answers
SOURCE: Unwanted Message
Generic Answer:
With most models of these monitors, hold in the menu key for more than 10 seconds.
If the above does not work, call the manufacture tech support. The monitor may need service.
Jerry G.
Posted on Jul 15, 2008
jason
  • 905 Answers
SOURCE: VGA displays all the time in the upper left hand corner
menu settings?
Posted on Oct 06, 2008
Anonymous
  • 13 Answers
SOURCE: Samsung syncmaster 931a... connected to computer
Hi, its unlikely to be the cable. Most likely cause of this is a faulty inverter board. If you are lucky it will only be 1 or 2 blown capacitors which are easily identifiable and replaceable once you have got inside it. it could however, be almost any of the components on the inverter board or even a failed backlight but this will require further testing and a knowledge of LCD monitor workings.
Posted on Nov 03, 2009
duane_wong
Duane Wong
  • 6826 Answers
SOURCE: a lot of dead pixels red and blue appeared in
Not much that can be done about this damage to the monitor, probably in shipping.
Posted on Jul 04, 2010
FONT IN HOTMAIL MESSAGES TOO SMALL
Change the appearance of incoming messages by clicking on "Options" in the upper right hand corner. On the left side of the page, click "Mail." Click on "Mail Display Settings" to change the number of messages it shows and to adjust other options.
I hope this is helpful to you!
Sep 24, 2011 | Microsoft Office Computers & Internet
It says drum error but the cart and drum is replaced with new and still can't get past the drum error message.
Hi There!
What you can do to clear the Drum Error message is to clean the corona wire.
  • Open front cover of the machine and remove the drum & toner cartridge assembly.
  • Remove the toner from the drum and gently shake the toner cartridge from side to side put it on a piece of paper to avoid scattering the toner.
  • Theres a blue tab on the upper left side of the drum, slide it from left to right, right to left about 5-6 times don't forget to put the blue tab back to it's home position(where the arrow is).
  • Put the toner back into the drum make sure it will click into place.
  • Reinstall the drum and toner assembly back into the machine and close the front cover.
  • LCD should display the date & time.
If you continue to receive the message try resetting the drum counter by doing the following:
  • Open the front cover
  • Press the Options key on the control panel. The display will show "REPLACE DRUM - 1.YES 2.NO".
  • Press 1 to reset the drum count.
  • Close the front cover
Hope this helps!
Vikroks
Mar 23, 2011 | Brother IntelliFax-2820 Laser Fax
Can anyone offer any suggestions on how to delete/remove titles displaying in the upper left hand corner of my TV screen and right hand corner? For example, if I am watching a program on CITY, the title...
I believe the "Caption Vision" is selected. By pressing the "Display" button on the remote it should toggle through the choices until "Display Off" appears. That should be all.
Mar 05, 2011 | Sony KV-32S42 32" TV
Display message reads - "key depressed"
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Jan 25, 2011 | Precor EFX 546i Elliptical Version 4
Have presario 6000. Would not boot but received message that new keyboard needed. Purchased "universal" aftermarket keyboard. New message "Hard drive failure imminent" and still would not boot to allow...
Prepare to Diagnose the Computer
Perform the following actions to prepare the computer for troubleshooting a startup problem.
1. Remove the battery and AC adapter from the notebook.
2.Remove any optical disks (CD or DVD), and disconnect any external devices or peripherals such as USB devices, printers, docking stations etc.
3.Plug the AC adapter directly into a functioning wall socket.
4.Press the Power button to turn on the computer.
NOTE:After the battery, optical media and peripherals are removed, the Notebook PC may startup normally. If this occurs see Windows starts after the battery, optical media and peripherals are removed .
Symptoms and Resolutions
When the notebook stops responding or displays an error message, let me know what symptom that most closely resembles what is seen on the Notebook PC screen.
* Screen is blank with no cursor or text
*An error message is displayed on a black background
*An error message is displayed on a blue background
*PC stops responding on a red Compaq or blue HP logo screen
*PC Stops responding on the Windows logo screen
* The Microsoft Windows 'Advanced Options Menu' is displayed
* PC stops responding with a blinking cursor is displayed in the upper left corner of a black screen.
*Password is requested but password is forgotten or lost.
*Microsoft Windows starts, but a 'serious error' message is displayed that prompts you to send an error report to Microsoft for evaluation.
* Microsoft Windows starts , but the PC stops responding or restarts automatically
*Display is very dim during and after startup
*Microsoft Windows starts, but runs abnormally slow
Jan 28, 2010 | HP Pavilion dv9000z Notebook
Water in LCD display
Once you get a dead pixel (black dots), there is no way to repair that part of the screen
Sep 20, 2009 | Computers & Internet
Jensen t.v model ts2750j blue screen red lock upper left
My Advent TV did the same thing. Blue Screen with a red lock in the upper left corner. Just press and hold the display button for about 10 seconds. It will clearn
Feb 02, 2009 | Jensen TS2750J TV
Mar 04, 2007 | Mag Innovision LT776s 17" LCD Monitor
Computers & Internet Logo
61 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
ThaMp3Doctor
ThaMp3Doctor
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
