SOURCE: Epson cx3800 paper feed problem
no you might have a paper jam somewere and mabe you ink rollers are dry you might have to tell the printer to to a pre test and clean and if there is a paper jam it should be a slot on the back by the roller should be a tap that shows the tollers look for a pice of paper jammed somewere in the roller you migh have to take the paper out to inspct it for a paper jam and if none mabe the print heads are dry and it dosent feed the paper then could be it ok clean the print heads tell the printer to to a roller clean and then after that if no paper jam no were try printing a page take all the paper out and feed it manually and if it prints then some printer want feed if you have filled the paper tray up try putting less and then try
SOURCE: epson r2400 won't feed paper
I had the same problem, then found these instructions for cleaning the feed roller:
http://www.museofineart.com/files/RollerCleaningProcedureRev2.pdf
I used the paper towel method and it's working fine now with no issues.
SOURCE: epson c90 paper feed problem
Is the message general error? The problem is tchip. When turn on chip is recognized by printer, but when start to print, printer "read" some information from the chip. Here is the error. Some pin at the chip for redaing the existence of chip, other pin for reading the information. Check connector between chip and carriage.
SOURCE: Epson R340 does not feed paper or feeds it crooked
two things I would do, first carefully flip the printer upside down, (anything that looks like it can flap open, tape it well), and jiggle it slightly and see if anything falls out.
second, i would clean the pickup roller with an alcoholic pad or swab, if its not easily accessible, you will probably need to take the upper an middle casing off, which I dont recommend.
thanks adi
SOURCE: Paper Feed on EPSON STYLUS SX115
go reclaim to the epson service agent or where you purchase.
Note: take all ink cardriges out. they dont need them.
