Question about Lenovo 3000 N500 Notebook
No display in laptop after powerred it on + Lenovo
When i turn on my lenovo g585 lap it start with one beep and comes the display and go boot with continuous beep sound and stuck the lap
Hi...
Gives continuous beep sound , When my laptop switch on (Lenovo G585). No display but leds (power & battery) were blinking.
Sep 10, 2013 | Lenovo G585 Laptop
HP Pavilion dv6-3007tu
what exactly is your problem? will it not start?
Jul 25, 2011 | HP Pavilion dv6-1122us Notebook
The display of my Lenovo G550 Laptop goes shoot down after short time. How to prolong the display time on my computer
Change the power settings. Under power settings you can set how long before monitor ' hard drives turn off.
Jun 22, 2011 | Lenovo G550 PC Notebook
My lenovo g430 3000 415228q not start just power on or no display any message
The reason your laptop comes up and shows nothing on the display is because the laptop is not reading any information from the components of the laptop.
First remove the battery of the laptop and install it back in.
If that does not help, then you should unscrew that laptop open then remove the rem and the hard disk and fix them back in properly.
This should help.
Take care and good luck
Oct 28, 2010 | Lenovo Computers & Internet
My laptop model is lenovo 3000 g430, as my laptop is turned on the screen goes on blinking....pls help me...tell me the solution.
1. Check your power cord & adapter. 2. If its working then check the battery, reseat the battery & check. 3. If available then check with another battery 4. If no, then remove the battery & switch on the PC in AC mode. 5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard. 6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall. 7. If still no display, connect an external monitor, check if display is comming. 8. If Display is coming then your LCD need to replace.
Aug 23, 2010 | Lenovo Computers & Internet
Lenovo s10 type 4231 ..power on ..no display..screen flash on turning off
try to removed the battery and unplugged the power cord,then while the battery is unplugged and as well as the power cord,press and hold the power button for one minute,thats the basic way of power draining the laptop,then after that,connect it direclty to the power outlet then turn it back on,if nothing happens,possible LCD or LCD cable,try to contact lenovo tech support for you to be able to send it to the repair center
Jun 25, 2010 | Lenovo IdeaPad S10-1208Uw Netbook
Laptop fan spin for 2 second and display not show
You must veryfi the CPU and try without battery or try it without charger with a already charged battery! This must work!
Sep 13, 2009 | Lenovo 3000 N200 Notebook
Lenovo X60 laptop display has stopped working
The backlight is broken. These are small flourescent tube lights about the width of a pencil lead. You dropped the laptop and the bulb broke. It will have to be replaced. The driver has nothing to do with your problem, reinstalling it will not get your picture back.
Dec 13, 2008 | Lenovo ThinkPad X60 Tablet PC
Lenovo 3000 N500 Notebook Logo
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
