SOURCE: LG LD-14AW2 (03 error)
agreed O3 is not a LG error code. OE is more likely and if so it could be the main pcb faulty, a blocked drain pump or a blocked spigot under the sink where the drain hose connects onto.
take care.
SOURCE: E1 Error Message
Yep, impeller motor problem.... mines done it twice now. Absolute piece of **** dishwasher. I HATE IT!
SOURCE: LG ld-14aw2 dishwasher
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
Remedy:
SOURCE: Model LD-14AW2 alarms after 1 minute of startup
The E1 error is telling you that there is a leak in the dishwasher. After confirming that there is no leak, even directly under the dishwasher (remove the kickplate and use a flashlight.)
After ruling that out, your problem is almost certainly caused by the drain hose between your dishwasher and your drain. There MUST be a 30" rise in the drain hose between the DW and the drain. If the hose just lays there, causing a siphoning effect (law of physics) that WILL drain water out of the dishwasher into the drain as soon as a wash or rinse cycle begins (after 1 - 2 minutes after they begin. Then the E1 error will be displayed.
The BEST way to fix this problem is to install an AirGap valve (almost free @ any hardware store) in your counter/sink and then running the short pipe to your disposal or sing drain inlet. If that is not possible or for a quick and dirty repair until you can install the AirGap, tie the drain hose to the bottom of the counter top so the rise is created.
Good Luck!
SOURCE: E1 display in diswasher
If you've checked everything, you will need to replace the impeller possibly.
Leakage error > Conditon: Excessive RPM of washing motor happened
during wash cycle due to water leakage.
Possible cause: Water leakage in hose connections,water is leaked by
damages. The motor water seal leakage of sump assembly. The height of
drain hose connection ( sink drain hose ) is not over 20". Impeller of
the washing pump is worn away.
according to the manual that i have just downloaded from the net,E1 code means.water leakage in Hose connections.
.water is leaked by damages
hope this helps,
keith
