HP LaserJet M5035 MFP Printer Logo
A
Anonymous Posted on Feb 05, 2014
Clean scanner glass - HP LaserJet M5035 MFP Printer
How to replace a broken scanner glass canon dr1210c
I don't know how the CANON DR 1210-C is assembled but I had an Artec and unscrewing it I could take off the glass.
1helpful
2answers
How to clean the underside of the glass in a HP scanjet 2400
Hi ,
You probably already found this :
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/performMaintDisplay/?sp4ts.oid=297429&spf_p.tpst=psiContentDisplay&spf_p.prp_psiContentDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c01275864-2%257CdocLocale%253Den_US&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
According to it , you should normaly contact a HP technician to have the job done . Nevertheless , I succeeded to clean the underside of the glass inside a HP Scanjet 5470C wich seems similar to your model 2400 . If you take of the lid of the unit , you should find two screws in the opening of the hinges . Unscrew them and lift up the the whole top of the unit . You might encounter somme kind of resistance during the operation but I finally succeeded to get the it free that way .
Best regards .
Sharp IR 2016 platine glass dirty
The cover plate is above the glass white surface of the scanner. If this is the same dirty stains will come out on copies.
The glass must be clean.
By feeding the original documents through the ADF, the scanner lamp is no longer the path to scan, the ADF is responsible for passing the original document over the scanner, while it remains still placed on the side under a thin glass is to a large glass side. This also must be clean, otherwise you will be black lines on each point or spot on the glass.
Good luck ...
14helpful
MY HP 8500A HAS STARTED PRINTING WHOLE PAGE BARCODE LOOKING LINES WHEN I PRINT OR COPY IN BLACK. COLOR LOOKS GREAT. IVE CLEANED THE PRINT HEADS AND ALIGNED THEM. ANY OTHER OPTIONS? THANKS
Solution one: Reset the product If there is static interference, or loose connections with the product, this can result in bands or lines in the copy, fax, or scan output. To resolve this issue, check the product connections and reset the product Press the Power button (c01602202.gif ) to turn on the product.Disconnect the power cord from the rear of the product.Unplug the power cord from the wall outlet.Wait 30 seconds.Plug the power cord back into the wall outlet. Reconnect the power cord to the rear of the product.Press the Power utton (c01602202.gif ) to turn on the product.Try to copy, fax, or scan again.If these steps resolved the issue , you do not need to continue troubleshooting.If the issue persists , continue to the next solution.
Solution two: Clean the scanner glass and scanner lid
If the scanner glass or the white underside of the lid has fingerprints, smudges, lint, dust, or other debris, this can slow performance and affect copy and scan quality. To resolve this issue, clean the product.Before you begin, gather the following materials:Several clean, soft, lint-free cloths
Mild glass cleaner
CAUTION: Use only glass cleaner to clean the scanner glass. Do not use cleaners that contain abrasives, acetone, benzene, or carbon tetrachloride. These substances can damage the product. Avoid isopropyl alcohol (rubbing alcohol) because it can leave streaks on the glass.
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Disconnect the power cord from the rear of the product.
  3. Lift the scanner lid. Figure 3: Lift the scanner lid
  4. Spray a clean, soft, lint-free cloth with mild glass cleaner.
    CAUTION: To protect the scanner, do not spray the glass cleaner directly on the glass.
  5. Clean the scanner glass with the lint-free cloth. Figure 4: The scanner glass
  6. Clean the glass strip next to the scanner glass with the lint-free cloth. Figure 5: The glass strip
  7. Dry the scanner glass and the glass strip thoroughly with a clean, dry cloth or chamois to prevent spotting, and then dry the white underside of the scanner lid.
    NOTE: Do not use paper-based wipes or tissues that can leave fiber residue.
  8. Clean the white underside of the scanner lid. Figure 6: The underside of the scanner lid
  9. Close the scanner lid.
  10. Reconnect the power cord to the rear of the product.
  11. If the product does not turn on by itself, press the Power button (c01602202.gif ) to turn it on.
  12. Try to copy, fax, or scan again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution three: Clean the automatic document feeder (ADF) Use the following steps to clean the automatic document feeder. Step one: Clean the ADF rollers and separator pad
  1. Gather the following materials:
    • A clean, lint-free cloth, or any cloth that will not come apart or leave fibers
    • Distilled, filtered, or bottled water (tap water might damage the product)
  2. Remove any documents from the document feeder tray.
  3. Press the Power button (c01602202.gif ) to turn off the product.
  4. Disconnect the power cord from the rear of the product.
  5. Lift the cover of the ADF until it stops. Figure 7: Lift the ADF cover
  6. Find the pick rollers and separator pad. Figure 8: Locations of the pick rollers and separator padLightly dampen a clean lint-free cloth with distilled or bottled water, and then squeeze any excess liquid from the cloth.
  7. Use the damp cloth to wipe any residue off the separator pad.
1helpful
2answers
The inside of the glass needs to be cleaned. How
The 3170 has a screw in each of the two slots where the lid inserts into the scanner. Remove the lid, remove these screws, and then the top portion of the scanner with the glass slides forward and off. Mine was stiff getting it off, but with some slight twisting and a bit of force it came off. You can then clean the glass.
2answers
Scanner glass clean
Cleaning the glass is rather simple. Take the 2 screws under the cover out. Now gently lift the top part of the scanner (some force may be needed). Then the scanner is in 2 parts and the glass can be cleaned inside and outside with a wet wipe glass cleaning pad. Dry the glass with a towel and inspect the glass with a lamp, that no cleanser remains are left. Now install the scanner in reverse order.
I have an HP Office Jet v40. No problems when I
Sannaer glass is dirty: Cleaning the scanner glass and white reference strip Follow the steps below to clean the scanner glass and reference strip: Remove any loose paper debris that may be present.
  1. Carefully clean the white reference strip on the underside of the scanner cover (or top cover) with a clean, lint-free cloth, moistened lightly with isopropyl alcohol. Clean only the white plastic part on the scanner cover.
  2. For those models that have a scanner glass, clean the scanner glass with a lint-free cloth, moistened lightly with glass cleaner. The HP Officejet K series and HP fax 1220 have a scanner opening instead of a scanner glass. Make sure that no debris is in the scanner opening. Use canned air to gently blow dust and debris from the scanner slot.
  3. Replace all removed components and close the unit.
  4. Plug the power cord back in and turn the unit back on.
  5. Make a copy to verify the lines are not present. If lines are still present and there is nothing visible on either the scanner glass or the reference strip, the unit will require service.
Instructions are on this HP link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu50325&lc=en&dlc=en&cc=us&product=60630&rule=30380&lang=en
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Smudges on scanner glass inside unit
hi im jules_09,the scanner glas should not be remove from the unit because if it is remove you might get a error code,so just get a soft cloth or a any kind of tissue and table tissue will do then apply a glass  cleaner on it then gently rob it on the scanner glass until the glass is clean just make sure the unit is off and ulplug.if the scanner glass is cleaned
k24674
Grand Canyon Tech
Grand Canyon Tech
