Question about Canon PIXMA MP810 All-In-One InkJet Printer
Fault in starting after many years
When start up 1- green light comes on. 2- yellow light comes on. 3- screen is fuzzy (like a tely off channell) first time it append no lights. then later it lit up with error code ? now as above screen lights up with nothing showing(only fuzzy screen) Harold Hill e-mail [email protected]
Posted by Harold Hill on
5 Related Answers
Anonymous
SOURCE: Canon Pixma MP150 Error code E 42
Had exact same problem. Scanner light should come on at power up. Found ribbon cable connecting scanner unit to base had come unplugged from socket on circuit board. The ribbon cable is one of three found near back hinge of scanner and is hidden underneath the other two. It should drape over the edge of circuit board and then plug into small recepticle on inner side of board. I plugged it in and printer works again. Hope this helps.
Posted on Mar 11, 2008
Anonymous
SOURCE: error code 5010
Yes, same thing happens to me...Error code 5010...and flashing green and orange...alternating lights.
I was trying to photocopy (in basic black, not colour). I had a few pages to copy. I got this 5010 Error code after EACH copy!
I had to turn off the printer after each copy and then turn it back on for the next copy. That's not the worse of it.....once I turned the printer back on and hit copy again...the printer took a VERY long time to scan the item for the next copy. It took me a good 40 minutes to copy 15 pages.
Sooooo irritating!!!!!
Anyone know what to do?
I've also had the paper jam on me tons of times. I am really disappointed with this product. I would not recommend this printer to anyone!
Posted on Aug 21, 2008
Anonymous
SOURCE: CANON IP 1880
i need install canon ip1880.. how?
Posted on Oct 05, 2008
Anonymous
SOURCE: CANON MP510 NOT WORKING
please..give me information.how to reset my printer MP510
Posted on Jul 15, 2009
pineworks
Clive
  • 4345 Answers
SOURCE: Current Problem on Printer """E5"""
This error means waste ink counter is full.
Solution:
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Press resume
Posted on Jan 25, 2010
The tv gets really fuzzy and changes color after watching it, but i think it has something to do with the wire ports because if i hit menu while its all fuzzy, and when the menu comes up it looks normal,...
check cable connections:
1. cable from wall to tv or to pvr. properly connected?
2. yellow,red and white in correct ports?
3. if HD, use green, blue and red to respective ports.
4. is remote properly sync to tv?
5. if no 3 above, get HDMI cable and connect to pvr.
Aug 12, 2013 | Westinghouse LTV-32w3 HD Television
I just replaced the batteries in my Jazzy 1170 PLUS. Now my speed control lights blink constantly and the chair is totally unresponsive.I have double checked to be sure the freewheel levers are totally...
According to my 1170 manual the flashing lights are error codes. 1 red = low batt., 2 red = left motor disconnected, 3 red = Left motor wiring fault, 4 yellow = Right motor disconnected, 5 yellow = right motor wiring fault, 6 yellow = Inhibit active, 7 yellow =possible joystick fault, 8 green = possible controller fault, 9 green = Solenoid brake fault, 10 green = high batt. voltage
Feb 13, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
Playstation 3 (PS3) Console: Whe i touch the red startup button it beeps and tu...
you got a YLOD yellow light of death when you get a yellow light briefly and then the red lights start blinking, you need to reflux the solder on the processors and apply heat to them, here is a link on how to do the repair, if you are not good at doing these kind of work, I would suggest taking it to a pro.
http://www.youtube.com/watch?v=XIm0Qk0CVTE&feature=related
May 17, 2010 | Sony Playstation 3 (PS3) Console
Start up fault for playstation 3
This is yellow light of death, your ps3 is broke call sony for info on repair
Apr 12, 2010 | Sony Playstation 3 (PS3) Console
My XBOX 360 is green and fuzzy, if you reset the game it will work for a little while fine but then goes back to the green fuzzy screen.
It's starting . The G.P.U is breaking away from
the main P.C. board . It will get worse with time.
You have three options
1 Send it to Microsoft ,wait 2-3 weeks and keep
your fingerd crossed.
2 do and x clamp mod on it this will get it
back to normal for 1-3 mounths.
3 Have a shop re-flow the G.P.U. back to
the board this is the most durable repair
cost will very 70.00-80.00 the 35.00 fix
is some else doing and xclamp mod that
you could have done yourself.
If you need more info just ask.
Rob
Nov 28, 2009 | Microsoft Xbox 360 Console
Horizontal flashing color stripes.1/2 second intervals on pic
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 07, 2017 | LG 42PG20 42 in. Plasma HDTV
Screen gone yellow and green
I have a 21'' NEC TV Screen and it about 3 year old. the colour has gone to yellow and green color and the red etc
May 10, 2009 | Samsung PPM42S3 42 in. Plasma Television
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Green lights on start up
You should have 3 green 2 yellow and 1 red.This is your maintenance indicator. When the 1 (last) green light goes out and a yellow light comes on its time for a service. The shop will reset the lights for you after the service is completed. If you do the service yourself and like to work on your own car you can buy a service light reset tool here. http://www.eurosportdesign.com/c-5-reset-tools.aspx?gclid=CPnumom1_pcCFRKLDQodkTwFDQ The R5B tool is the one you will need. It's on sale right now.
Jan 08, 2009 | 1999 BMW Z3
Canon PIXMA  MP810 All-In-One InkJet Printer Logo
52 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
