Question about Samsung Washing Machines
Drain pump automatic starts once I hit the power button and its continue to drain out the water at the beginning of a cycle. So It would not move the next cycle because of no water in the washer and it would give an error message of "Low Water Pressure". This washer is about 3-4 years old. I think it's kind of shame for a $900 washer
Do pull the plug out first
not funny dancing with the machine
have you checked the pressure pipe for any cuts
look near the pressure switch area first
Posted on Feb 06, 2014
Testimonial: "All the pipes are fine. I did pull the plug, replaced the drain pump and the same thing still happen. I'm thinking is the PCB or machine control board. But I want to get all opinions before ordering that pricey part."
SOURCE: Washer won't drain or spin
your not going to like me? its the programer playing up,,,pricy part too?
see i was right,,,you hate me now!
Posted on Jun 08, 2010
SOURCE: Won't advance to spin cycle from drain cycle
install new timer....thumbs up...
VE6GAR 73 88 99
Posted on Aug 11, 2009
SOURCE: whirlpool duet sport wfw8300sw00 f-21 error
Unplug the machine. Unscrew the 3 screws under the front edge of the washer. The service technician manual is attached to the panel that slides down and off. Find F21 code. See suggested procedures. Note: My drain pump filter had a baby wash cloth in it along with some change that was disrupting the flow. It is exceptionally easy to remove, clean, and reinstall. Just line up installation notches when reinstalling. Whirlpool should have mentioned this filter in the User & Care Guide, but I could not find it anywhere in there.
Posted on Mar 20, 2009
SOURCE: Washing machine drain problem
you know, it sounds not like a mechanical issue. Sounds like your control circuitry is off kilter..
Posted on Mar 09, 2008
SOURCE: GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Posted on Feb 07, 2010
Jun 29, 2017 | Dishwashers
Feb 11, 2015 | Viking Dishwashers
Jan 25, 2014 | Washing Machines
Oct 30, 2013 | Beko Washing Machines
Jul 11, 2013 | Motorola Mobility Defy Cell Phone
Oct 08, 2012 | Washing Machines
Jan 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Oct 30, 2009 | Dishwashers
May 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sep 22, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
3,864 people viewed this question
How did you fix this issue?
Probably buy another washer.
