Question about Tag Heuer Link WJF1417.BA0589 Watch
Can't see how to open the bracelet - Tag Heuer Link WJF1417.BA0589 Watch
Posted by Linda Kasko on
Do copper bracelets help eliminate pain?
There is evidence that copper against the skin does have some influence on relieving joint pain!
Oct 04, 2014 | Bell Solid Copper Signed Bracelet...
Tip
How to manage your SUBMARINER's size to fit your wrist
Take of your ROLEX, look on the inside of the bracelet. Near the area where you have the crown, there is a miniature circle, push with your thumb on it with strenght, you will hear a click . You pull your bracelet , it will open, then you look on the sides of the bracelet, and you insert a needle into the little screws on both sides, and then you choose the size you wish for your watch , and then put the circle back and close everything again.
on Oct 10, 2010 | Rolex Oyster Perpetual Submariner Date...
Pandora bracelet
The silver bead that doesn't move, at the ends of the bracelet, opens up as it is hinged. Take your finger nail and push in the crack of this bead. This should open it up. When you go to close it, make sure you press hard and hear a snap.
Jun 07, 2013 | Watches
I need to buy new bracelet
mcdevito75 here, BEST BET for your Ebel watch, look for a small watch repair shop in your area, to order a new bracelet.
Jul 13, 2010 | Ebel Type E Stainless Steel Rubber Strap...
Cannot open bracelet on Bulova 11606355 watch
Try taking your watch to a local watch shop.
If there is something wrong with it, you can only tell by handling it. Alternatively if there is a special way to do it they will probably know it.
Apr 24, 2010 | Bulova Watch
How to adjust expandable bracelet pleaseI would like to remove links to make it smaller.
If you are ready to take that risk, here is how you can do that.
First- get watch on your wrist and by squeezing the bracelet count how many links you have to take out to make it tight enough (say 4 for example).
Check the sides of a bracelet. You will notice that the upper band metal is flipped over the bracelet side. Take tweezers or small pliers and unbend one of these. Try to do as little damage as possible.
When it's done, you will see two metal staples inserted into the bracelet. You have to pull them out. While pulling out, remember how they where positioned, as you will need to drive them back in the same manner.
So, when the staples are out, do the same on the other side of bracelet. Now you have bracelet in two halves.
Count off 4 links and undo the staples in joint of 4th and 5th link in the same manner as previously.
When links are out, take the staples and drive them back into the bracelet joining two ends together. You have to do that exactly the same way and position as you took them out.
When all staples are in place, bend the metal back over the bracelet sides.
BE WARNED: as you gonna do it first time, be ready that you can damage the bracelet or can not put it back together.
Good luck.
Jul 29, 2009 | Casio Watches
I have a bracelet link bracelet expansion bracelet watch I need to remove some links
Check the sides of a bracelet. You will notice that the upper bands metal is flipped over the bracelets side. Take tweezers or small pliers and unbend one of these. Try to do as little damage as possible.
When links are out, take the staples and drive them back into the bracelet koining two ends together. You have to do that exactly the same way and position as you took them out.
When all staples are in place, bend the metal back over to the bracelet sides.
Good luck
Dec 21, 2008 | Timex 2J611 Watch
I can not open rolex bracelet
Sometimes Rolex bracelet clasps are very tight and this only shows the quality of the watch.
Don't be afraid to pull the clasp hard enough to open it- nothing will brake as Rolex is designed for quite hard use.
If you can't do it by hand, try to use flat butter knife end as a lever.
Dec 12, 2008 | Watches
Taking links out of a tag watch
TAG Link watches has very distinctive bracelets, but there is the price to pay for it- as they do wear out it's almost impossible to repair and costly replacement is needed.
In your case: open the clasp first and check if the bracelet end links has holes on sides. If yes, then find which end of the pin is split or have groove in it. This end Must come out first! Use small hammer and hardened steel pin to drive bracelet pins out.
When assembling bracelet back together, note that the pins MUST go back exactly the same way as they came out (blunt end first in and split end last).
Good luck
Arthur
Dec 25, 2007 | Tag Heuer 2000 CN1110.BA0337 Wristwatch
Tag Heuer Link WJF1417.BA0589 Watch Logo
27 people viewed this question
Top Tag Heuer Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
