Question about Crosman (4032)
Co2 cartridge leaks when inserted,
What size seal does it take
Posted by frank desena on
1 Related Answer
Anonymous
  • 6 Answers
SOURCE: After inserting and compressing the CO2 cartridge, the CO2 leaks
You need to check the rubber o-ring seals both in the plug and there could be another up in the gun where the cartridge end meets the inside. If you have a broken o-ring you should be able to find one that fits at your local hardware store or store that sells air rifles. Hope this helps.
Posted on Jul 12, 2009
Hi, I am trying to remove a brand new CO2 cartridge I just put in a new Gamo PT-85 Blowback pellet hand gun. As I'm unscrewing it, gas is leaking out. HELP.
Hello K Brink,
Kind of like deja vous (all over again )...
Pretty sure: This is the same Question I answered
yesterday (no / yes? ).
There is no going back... Once the CO2 cartridge is
pierced... there is no way to salvage the cylinder
until it is FULLY expended...
If you unscrew the chamber the CO2 will ALL be released.
Just ONE word... If your cylinders are depleted... ALWAYS
check that the SEALING O-ring stays with the hand-gun.
Just make sure yur SEALING RING is still in the "gun"
and NOT STUCK to the ... co2 CARTRIDGE.
I am just saying...
((been there... Done that))...
Carnac the Magnificent
Nov 29, 2017 | Gamo Optics
Hello K Brink,
I am just saying...
My Crosman 1008 Repeat Air pistol leaks all CO2 out
The crosman 1008 does indeed fire pellets! NOT BBs. ONLY pellets.
Feb 03, 2014 | Crosman (4032)
Co2 install
Your seal is probably out...
Jul 29, 2013 | Crosman Optics
When i instert the co2 in my airmag c11 it just releses all of the co2 and its all wasted what do i do???
Take a short strip of teflon tape and put it over the end of the co2 cartridge, make sure its in straight and tighten, works good.....:)
May 03, 2011 | Crosman (4032)
Air leaks out when installing co2
The Phantom Break-Barrel does not use CO2. It is a spring-loaded break-barrel weapon. If you really do have a CO2 gun, check the rubber seal around the outside of the cartridge puncture needle.
Feb 18, 2011 | Crosman Phantom .177 Caliber Break Barrel...
Air pistol c02 replacement
Well that takes me back! I have an old Daisy 1200 -- essentially the same pistol in a different brand.
My Daisy has a hand-turn screw to hold the CO2 cartridge in place, and you have to tighten it quickly until the leaking stops. It does this by pressing the cartridge up against a nylon washer to form a seal (and of course pushing it into the piercing pin to get the CO2 out!)
With age, I'd expect that nylon washer to get stiff or crack, making it harder to form a good seal. You don't need an exact replacement part, but if that's happened to yours then you will need to replace it with something more-or-less the same size as the original.
May 30, 2010 | Crosman 1377 177 Single Shot Air Pistol
Daisy Powerline 1700 leaks CO2 very slowly but
Replace the seals.
Recommend an eBay or Google search or contact Daisy directly here:
https://www.daisy.com/contactus
Oct 17, 2009 | Daisy Toys
Jul 12, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Crosman (4032) Logo
158 people viewed this question
Top Crosman Optics Experts
NOEL
NOEL
gbob59
Are you a Crosman Optic Expert? Answer questions, earn points and help others
