Question about Canon MF8350Cdn AllInOne Laser Printer
Close front cover error
Front cover is not closed, can't get the error to go away
Gail Damerau
Any pictures for this issue
Posted on May 22, 2020
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: my mp600 keeps saying close inner cover-which is closed
I had the same issue, turning off didn't solve it.
There's a plastic flap the width of the print tray just inside that I flipped up and it solved this problem. It is directly in front of the ink tanks. I'm assuming we flipped it down and forgot about it. It seems it needs to stay up, although you wouldn't notice it when it flips down when you close the top, as it closes just fine with it down. It's easy to overlook. This took me a few hours to realize.
The top of the flap has a half circle cut out of it in the middle.
Posted on Dec 18, 2008
Anonymous
SOURCE: "Close the front cover" sign even the door is closed already
is your problem solved ?
Posted on Mar 31, 2009
Ronnie Gregorio
  • 118 Answers
SOURCE: i have a canon ir 400 the machine shows close the
Try to open and closed the front door several times,If the left cover and the front door are closed properly and still showing "close front door" most
probably the internal contact of door switch are not good , door switch replacement is needed
Posted on Jul 06, 2009
Xanda Frederica
  • 183 Answers
SOURCE: The inner cover (flap in front of cartridges) is
When the message shows means inner cover sensor is faulty so it cannot detect inner cover state correctly. Try to clean the contact sensor with contact cleaner is good idea since it sometimes an oxidation occurs. Many times I success fix the problem like this.
Regards,
PrinterClinic
Posted on Jan 03, 2010
Jaime Velez
  • 31 Answers
SOURCE: canon machine message front cover is close but
there are switch behind the front door that are activated by the front cover. you may have a broken or missing actruator pin on the front door. look very carefully on the door for anything that seems to be missing. if ther is just use a piece of paper to actuate the switch. jaime
Posted on Jul 16, 2010
Close Front Cover For Toshiba E-studio 350
There are many possibles that can cause "Close Front Cover"
Check the front cover actuator, switch. If all covers, switches is working fine, probably power supply is faulty.
Dec 02, 2015 | Toshiba e-Studio 350 Copier
How to do periodic maintenance 0088 in Toshiba Studio 2330c
Toshiba e-STUDIO 2330c
Is given error message "Close Front Cover". The front cover is closed and I can not get error message to go away.
Where can I buy Power Supply (6LG03347000)
Mar 23, 2015 | Toshiba E-studio 2330c 2830c Color...
Close side cover error tray
You see front cover switch if front cover knob not touch then this messege appear OR check power card & front cover connection
Nov 06, 2013 | Toshiba e-Studio 350 Copier
Kyocera Mita KM-2530 error close front coveR
The front door switch or actuator is broken or the door may be warped .Have you tried putting pressure on the front cover? as this may help to indicate if the switch is faulty.
Sep 10, 2012 | Kyocera Mita KM-2530 Laser Printer
Brother mfc-7460dn toner replace toner will not go away
Remove drum/cartridge, close front cover, Menu, 1. General, 8. Replace toner.
Replace drum/cartridge. Close front cover.
May 07, 2012 | Brother MFC-7460DN
E 803 error in 3170
this is Door close error.
Check if the door's nose that goes into the sensor hole broken, check the door closed/open switch, Check on connection of the front cover open/close switch (SW3) , Replace the front cover open/close
switch.
It's hard to locate it without service manual, but... if you manage to remove the plastic cover over the toner inlet then you will be able to see the hole where the nose of the door ( inner side of the door ) goes into.
For service manual, You can send me the mail on [email protected]
Hope that helps!
Jul 25, 2011 | Canon Office Equipment & Supplies
Message 'Clean Sensor' has appeared. Followed advise to open Cover D and close it again but to no avail. Has anyone got any other suggestions, please?
Follow the steps below to clear the "Clean Sensor" error message.
  2. Slowly close the cover again. c2600_close_cover_d.jpg This action will move the lever shown below and clean the sensor.
  3. Open and close the cover several times. Once the front cover is left closed the printer will start to calibrate.
Once complete, the error should no longer appear and the printer should resume normal operation.
Note: If the error message is still apparent after following the steps above, contact Epson for further advice.
Nov 16, 2010 | Epson AcuLaser C2600N Printer
Front cover of phaser 8550 won't close correctly
You can download the service manual free at ww.eserviceinfo.com
Aug 18, 2009 | Xerox Phaser 8500/DN Printer
Error "close front cover"
make sure the protrusion that activates the switch telling the machine that the door is closed is not damaged.
Apr 02, 2009 | Ricoh Aficio 1018 Printer
Canon MF3220 System error E000
Hi there Mark765,
According to Canon, the unit needs to be reset.
To do this: Open the front cover. Close the front cover. (I'm serious)
Click here for the canon page concerning this error. It's alsao a good source of additional info.
Let me know if the error persists (or goes away)
Remember: Good things come to those who Rate!
Mike
Aug 15, 2008 | Office Equipment & Supplies
Canon MF8350Cdn AllInOne Laser Printer Logo
699 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
