Question about Bosch Axxis WTL 5410 Electric Dryer
Bosch WTL5410UC Condensing Dryer won't heat or tumble a drying cycle. No error codes, the control panel looks as if the dryer is working.
I have an older Bosch Axxis dryer that I purchased used. It has been working great for the past 2 months. Then, yesterday is suddenly it stopped working. It allows you to select a program and even press "Start." But, once you start the cycle, nothing happens. The control panel registers everything the same as if the dryer was going through the cycle as normal. The timer even counts down and give an "End of Cycle" signal, but nothing is happening inside. No heat, no tumbling, no nothing. I just cleaned out the dryer filter and vacuumed out some lint (it wasn't really that bad, but I figured it couldn't hurt). Anything else I should try before I call the only Bosch Tech in the area?
Posted by Paul Jellema on
2 Related Answers
Anonymous
  • 8 Answers
SOURCE: Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Posted on Dec 15, 2007
Anonymous
  • 51 Answers
SOURCE: WTL 5410 BOSCH AXXIS CONDENSATION ELECTRIC DRYER
the thermostats at the element have to be replaced, they burn out prematurely if the condensor unit is not cleaned on a regular basis.
Posted on Feb 02, 2010
I keep getting E15 Error code on my Hoover Tumble dryer flashing. The dryer is working, but heat is cold.
Control board fault. See... https://www.espares.co.uk/advice/careandmaintenance/how-to-fix-an-e15-error-on-a-hoover-washing-machine
Oct 05, 2016 | Hoover VHC391 T-80 Dryer
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
if its a Kenmore model then this message says that the button control board has lost sight of the main control board , but its been my experience that this maybe able to be reset and it may never come back or it will not reset and the control board will need replaced (50/50)
cycling power may reset this
Jan 30, 2016 | Dryers
Whirlpool AWZ 410 washer dryer is not generating any hot air when drying. The dryer drum is tumbling but with cool air only.
Unplug the unit and take the top with the screws holding the lid on. Take a look at all of the wires on the top of the machine. You might notice broken/burnt wires on the safeties that are close to or that directly activate the heating element located in the blower housing located at the top of this washer/dryer condensing unit.
Nov 26, 2013 | Whirlpool LER4634J Electric Dryer
E15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
Our Bosch Classixx Condenser Tumble Dryer works but there is no heat. I have cleaned the Condenser Unit and the filter and emptied the water, but still no heat. Please advise. Thanks Craig
my wte84105gb condenser dryer (bosch) as a symbol on it looks like a glass with wavey lines inside it will not dry please advise what to do .
Feb 26, 2010 | Bosch Axxis WTA4400 Dryers
I need advice on dryer for my kitchen.
This isn't an add its two different units that I have installed and are both condensation dryers. Which in my opinion is better for your needs and lacking venting.....LG and Miele also have 15 cycle so now the decision is what your needs and Budget. Prices range from 700-1500 but well worth the money. Bosch Axxis Condensation Dryer (model: WTMC8320US) you can machine-dry clothes without venting hot, moist air (or indeed any air at all). The Axxis Condensation Clothes Dryer condenses the moisture in the hot air to water and releases it through the water the need for ducting and a blower motor to help expel hot air. Ventless dryers make installation easy, fast, and very cost effective. And since little heat is lost when the air passes through the condensing chamber, it takes very little energy to raise the temperature back to optimal drying levels, thereby saving you energy. The Bosch Axxis ventless dryer features the unique DUO TRONIC system with 11 auto dry cycles that tailor the drying cycle to your clothing. And Bosch's exclusive DUO TRONIC system combines two moisture and three temperature sensors to automatically deliver precision drying. This machine virtually operates at the touch of a button to prevent over drying and damage to your clothes. With the stacking unit I think this is your best option due to keeping moisture, and later mold problems due too condensation. The Ariston Stackable Condensing Dryer ASL75CXSNA is the perfect choice for any home lacking venting capabilities and is the largest condenser dryer on the market, bringing the convenience of a compact laundry system to any home. Wrinkles are minimized with the innovative Pre and Post CreaseCare feature - periodically tumbling the clothing until you come back to remove it - and the handy Bidirectional Rotation of the stainless steel drying drum. Clothes gone musty from long closet stays can be quickly and easily refreshed with the ASL75CXSNA using the intuitive Air Fluff cycle, and the 12-hour Delay Timer allows for freshly-dried loads at your convenience.Key features include: spacious 16-pound load capacity; 180º reversible full metal door; removable lint filter; included stacking kit; Easy Iron option; and electronic Sensor Controls. The Ariston Stackable Condensing Dryer ASL75CXSNA has the high class, top performance, and compact convenience to be a welcome addition to any energy efficient home.Note: This item pairs with the matching Ariston Stackable Washers. I hope this was helpfull~ Have a good day
Feb 05, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Tumble dryer not working
I managed to solve the problem the following way: I noticed that if you unplug the Sensor-NTC(part nimber 154431 https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WET2820GB%2f13 ) that controls temperature of air in the air channel, the drying cycle runs as you describe above. So this circute was checked up to the power module. Contacts of the Sensors plug were tightened; I think this solved the problem; resistance of the sensor checked. It must be 4.8K at 25 degree C. and decrease when temperature increases. I dipped the sensor in a glass with hot water.
Oct 25, 2007 | Bosch WET 2820 Front Load Washer / Dryer
"CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Sep 01, 2007 | LG WM-3677HW Front Load Washer / Dryer
Leak during tumble cycle
more than likely that the seal for your condensing chamber has become faulty easy fix undo any screws that hold the condesing chamber on get some bath/shower sealant that is waterproof put this around the chamber and put it back on you will have to leave it for a couple of hours but this should fix the leaking problem its not totaly common but this does happen m8
Dec 27, 2006 | Bosch Classixx WVF 2402 Front Load...
Bosch Axxis WTL 5410 Electric Dryer Logo
Top Bosch Dryers Experts
Lawrence Oravetz
Vernon Taylor
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
