Question about Pyramid 4000 Mechanical Time Clock
Pyramid 4000 time clock won't pull time card through
I need the instruction manual for the SEIKO pyramid talking clock from 1984.
You might try starting at this page from Seiko
(I could not further because you do not give exact model number)
Instruction booklets
10.June.2015
Jun 10, 2015 | Seiko Gold Tone Pyramid Talking Alarm...
I need to know how to alter the volume on pyramid T-10 talking clock for the blind
Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
Jan 24, 2015 | Pyramid Car Audio & Video
Fan is to loud
It might need the fan plugged in to make a full curcit and that's why it won't turn on
Mar 28, 2013 | Pyramid XPA-100 Amplifier
Time clock not accepting the time card
needs to be serviced. a sensor may be not working. Try www.gatewaytime.com
Mar 18, 2013 | Amano BX-1600 Electronic Time Clock
What does Error 1 mean?
Error 1 - Indicates time card stuffing. If an individual tries to force a card into the unit, the 4000/4000HD will accept the card but will not print or store any payroll data. If this situation occurs, an ERROR 1 will show on the front display and the card will not be "punched".
Solution: Rerun the time card through the time recorder without pushing on the card.
Resource 1 : Owner's Manual
Mar 01, 2011 | Pyramid 4000 Self Totaling Employee Time...
Cuisinart COD-4000 Stopped brewing coffee; lost clock and timing
I have no solution, however I have the same problem. Wondering if you have resolved the problem yet?
Feb 16, 2010 | Cuisinart Brew Central 12-cup Coffee Maker
Pyramid arctic 4ch amp pb1617x goes right to protect mode when turned on wires are good fuses are good to. how do i fix it
pull out 1 rca jack at a time and try it..usually speaker wires touching...or blown speaker
Nov 08, 2009 | Pyramid PB1617X Car Amp
Pyramid cdrcs90mp
Hi there, the installers forgot to wire your auxiliary wire to the proper connection. this is the reason why the clock doesn't stay on after the ignition switch is turned off. i assume they just wired the aux wire with the power wire, which is wrong. this is causing the random power button scramble. Although, the aux wire is crossed into the power wire, this random power button scramble could be a manufacturing mistake as well. hope that helps and, thx for using fix ya.
Feb 18, 2009 | Pyramid CDRCS90MP CD / Cassette Player
Pyramid 4000 Mechanical Time Clock Logo
55 people viewed this question
Top Pyramid Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Pyramid Audio Player and Recorder Expert? Answer questions, earn points and help others
