Question about Pioneer PRO-710HD 64" Rear Projection Television
Hello how do i set the convergence manualy on a pioneer elite pro-710hd projection tv i dont have the remote and dont know how to bring the menue up on the tv
The green is off lline and needs to be set but i dont know how to bring up the menue on the tv seeing as i dont have the remote
Posted by Phil Boyer on
gludwick2
  • 60 Answers
You MUST have the remote to perform service operations on the Elites. Look on ebay or do a google search for Pioneer 710 remote.
There is no way to manually do convergence without a remote, and no way to call up the convergence menu.
Posted on Jan 08, 2015
2 Related Answers
Anonymous
  • 1153 Answers
SOURCE: Pioneer Elite PRO 710HD 64" rear projection tv
You could get the old one and have them match it up. If not try www.pioneerservice.com
Posted on Sep 17, 2007
ladywinn
ladywinn
  • 5138 Answers
SOURCE: It has blue and green arc colors showing up with
Replace Both of Your STK ICs They are Big Black ICs will have STK392-110 on them upgrade ICs to 120s-150s,or 180s Call Mat Electronics for parts
1-800-628-1118 ICs will be on the Left hand side of Chassis Mounted on The very First board,there are screws holding board on Fame/ board also plugs in bottom of chassis.
Posted on Jan 21, 2010
Can I use a universal remote to adjust my settings for the elite Pro 710 HD?
I doubt it, we have in our shop about five of their remotes and each only works on one or two models--bite the bullet to get another or if you have the original but it does not work, most shops can fix that for a reasonable price.
Dec 14, 2012 | Pioneer PRO-710HD 64" Rear Projection...
I have 65 inch pro elite 710hd 6 years old. Do I have to get analog box
hello,
Yes you still have to get digital to analog converter. Although you can feed a hd signal through the component inputs, the tv is still set up to only receive analog signals through the coaxial input
hope this helps
Jan 14, 2011 | Pioneer PRO-710HD 64" Rear Projection...
Pioneer elite tv turns off from a pop sound and manual says-will
It is most likely the power supply. Do not try to fix this yourself. There are LETHAL voltages inside such a TV, which can persist for WEEKS after it has been turned off.
Jan 09, 2010 | Pioneer PRO-710HD 64" Rear Projection...
The convergence chip is going in my pioneee elite
Yes there are two ICs in your model they are around 20.00 each for quality ICs. Cheaper ICs are available but I wouldnt recommend them as theyre most likely the inferior chineese made ICs and they fail quickly.
Nov 27, 2009 | Pioneer PRO-710HD 64" Rear Projection...
Pioneer 710 hd power/not turning on 10/12/08
When the set goes into protection BANG like that, without any intermittencies, usually the convergence ICs have gone out and need replacing. I recommend using the STK 392-180s, which are the stronger upgrade to the 392-110s used originally. You'll need 2.
Mr Bob
www.imageperfection.com
510-278-4247
bob at imageperfection dot com
Oct 13, 2008 | Pioneer PRO-710HD 64" Rear Projection...
Pioneer Elite Pro 710HD Rear-Projection Television
no reset sequence. usually when the protection kicks in without any warning, it's the convergence ICs needing replacement.
Mr Bob
Sep 16, 2008 | Televison & Video
Sep 17, 2007 | Pioneer PRO-710HD 64" Rear Projection...
Pioneer PRO-710HD 64" Rear Projection Television Logo
Top Pioneer Televison & Video Experts
Demonic-2011
Demonic-2011
Raj Patel
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
