Question about Marantz Audio Players & Recorders
The converter should not b e a problem. It's time to ask a technician or a HiFi shop, an internal short circuit is blowing the fuse. Don't insist.
Posted on Apr 27, 2014
SOURCE: VSX-D466S
Bad News!
If the fuse is in the mains (power line) you could have a bad rectifier or other problem in the power supply. Most amplifiers nowadays have switching power supplies and they are not as easy to troubleshoot as the older linear supplies. If an Output or driver transistor is shorted, the power supply fuse will dump just as fast, load or no load.
Mister Phil
Posted on Apr 09, 2008
SOURCE: the fuse keeps blowing in my marantz pm-57
Goo day sir, the T on the fuse has nothing to do on you marantz fuse blowing up, chances are you amplifier is shorted, check you IC amplifier/power transistor for shorts. Check also your speaker impedance. usually they are 8 ohms. You can use a technician's multitester device to check the impeadance. An imbalance or mismatch speaker can cause a fuse to blow and destroy your amplifier. hope this helps.
Posted on Jul 31, 2009
SOURCE: Hi I have two marantz amps witch cut in and out when run from
In stereo terms your system is "clipping" which means you are pulling more amps than the system can handle. If it happens only when you use the mixer, I'm thinking the mixer cant handle the power. Check the specs, It should show maximum amp input.
Posted on Jun 04, 2010
SOURCE: hello i have a marantz pm-47
Hi mas_66,
Make sure that the fuse is the same rating with the old one.
If still symptom persist, I've suspected that your output IC is shorted.
You may hang this IC, then power up the unit.
Observe what will happen, if this cure the symptom then this is a clear indication that this IC is shorted and made the fuse blown while it is in the circuit board.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 08, 2011
