My stove went out while cooking on it Saturday night, i had 2 eyes going and the oven on, its cut off on me a few times before, i usually flip the breaker and its ok, but this time, the display went out,when i turn the eyes on, the indicator light comes on and the clock display tries to come on but doesnt stay, i pulled the oven out and noticed a black "spark" mark on the wall. Help. Thanks
SOURCE: Amana electric range - light but no heat
Hi rablef,
I would recommend you check your fuse or breaker box for a blown fuse or tripped breaker. If you are only getting one leg of your 220 volts the you will have the problems you have listed. If you have no breaker or fuse problem you should then check your range cord for possible shorts or hot spots. Then work your way to the terminal block on the range. It definately sounds like you are only getting 110 volts to your range. I hope this will FixYa.
Good luck, Mike
SOURCE: Hello. Regarding my Amana range (MODEL: AGDS902),
You will have to replace the bottom element.
John
SOURCE: Amana stove, oven igniter works but oven wont light
although the bake ignitor appears to be glowing, it probably does not glow with the intensity it needs to open the safety valve assy, VERY common problem, go aheadand replace the ignitor, this will correct your issue
Testimonial: "100% correct, I ordered the part from on line and it was a very easy fix and the oven is working great. Thank you"
Here
is a tip that I wrote to give details about why your cooktop will not
spark to light the burners..
Cooktop
Range Stove spark ignition does not work
heatman101
