EliteGroup ECS G733 Notebook Logo
A
Anonymous Posted on Feb 05, 2014
Lines on screen - EliteGroup ECS G733 Notebook
Vizio VW46LFHDTV10A vertical lines on either side of the screen. I tapped screen and left side lines disappeared.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Diagonal lines at 45 degree angle from left top to right bottom of screen
db:: 4.31::Diagonal lines on tm2 screen? fz - Hivmr
www.hivmr.com/db/fzap9jk8dp87mcjk3cc9jsp7fzxk7pz1
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
3M Privacy Filter for Laptop diagonal-14.1" viewing screen ...
www.amazon.com/3M...diagonal-14.../B00006B8A9
Amazon.com, Inc.
Rating: 3.8 - ‎1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3Mâ„¢ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
FZ190: Faint Diagonal lines on screen? ' NotebookReview
forum.notebookreview.com > ... > VAIO / Sony
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
2answers
Horizontal lines in lenovo r61
This is a indicator of defective LCD screen, the only option is replace the laptop monitor, go to www.ebay.com Type make and model of laptop, refine search to screen to get an idea of pricing.
Dell 1720 screen
If you can see the vertical lines during POST, try to check the vertical lines in BIOS. If the vertical lines are there in BIOS, the only thing you can do is to replace your LCD screen.
Toshiba Satellite P105-S6124 Screen lines
Are these lines on the screen during the whole boot process? If so then the screen cpu and/or the video cpu has gone bad. Connect an external monitor. If the picture is clear, no lines, then the problem is the LCD screen. If the lines appear on the external monitor during the boot process then the mother board will need replacement.
Good Luck
Line in my lc screen
A line from top to bottom or side to side is a dead or failed pixel sensor. There are hundreds of pixel sensors at the edges of the screen, when one fails it causes a line, the line can be red, blue, white, or black. Unfortunately, there is no way of repairing the line, other that replacing the screen.
Screen has lines
Most likely youve damage the lcd screen either by dropping it even though you didnt, but that would be the only cause this problem, line on a lcd screen are usually cause by a broken power current thru screen or a cracked lcd screen maybe it was defective in the first time. I dont know, but line are usually means no power or no information going thru screen.
need to be replaced.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
1helpful
2answers
Vertical lines in my laptop screen
Check it on External monitor prior to replacing the screen.. If the problems there as well its not the screen..
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
