Question about Haier HTF20R21 20" TV
Service code green colour extra
Posted by Nirupam Mandal on
Speakers
On tower computers made in the past 8-10 years, the speaker socket is colour-coded so you can easily find the right socket (this colour coding system is known as AC'97).
The speakers go in the light green socket, and there will usually be two others, one is light blue for secondary sound output, and the other is pink, used for microphone input.
Computers with older sound systems may have all black sockets instead, invented before the AC'97 system of colour coding, in which case there will usually be a very small picture indicating which is the speakers.
The easiest way with older black socket designs is to start the PC playing music, and then go thru each socket (it's perfectly safe to plug speakers into the wrong one of the available sockets - none of these things carry high voltage of any kind.
High specification modern towers may have 6 or more sockets available, as these are needed for surround sound Dolby 7.1 speaker outputs. With that type, they are split into 2 groups of 3, with 1 group covering the standard pink, green and blue sockets, and then the extra ones next to them.
You may also see a small square audio socket on your PC if its top of the range, and this may have a red glow from it. This is fibre-optic audio output, and you should avoid ever looking directly into these illuminated sockets as they are like a laser light inside.
Sony wega 28 inch colours wrong, circle on screen
It sounds that there is some magnet near by TV that is affecting picture tube. Please remove any extra speaker or any thing that has strong magnet inside, unplug TV for 20-30 minutes, replug back in, turn it ON, hope that will solve your TV problem.
Thanks.
No connection to internet
There are 2 common colour codes for Cat5e. In Australia the most common is T65A Colour code for this is below
Pin 1 is Green T3
Pin 2 is Green R3
Pin 3 is Orange T2
Pin 4 is Blue R1
Pin 5 is Blue T1
Pin 6 is Orange R2
Pin 7 is Brown T4
Pin 8 is Brown R4
A very good link for this is http://www.grech.net.au/networking/utp/index.html
Hope this helps,
Cheers,
Jason
1helpful
Match color of my bike
1999 GL1500SE
Candy Spectra Red, R176C. Inset panel colour is Candy Garnet Red, R199C
Pearl Glacier White, NH326M. Inset panel colour is Glacier White Accent Gray, no code available
Pearl Twilight Silver, NH390M. Inset panel colour is Dark Silver, no code available
Pearl Mercedes Green, G167. Inset panel colour is Dark Green, no code available
Gloss Black, NH1Z
Colours turns blue and green from HD channels
The most likely cause of your problem is the cable box HDMI output. If you have some extra cables, try connecting the TV to the cable box using the component connections. I'll bet your problem will go away. Don't let the cable company lie to you; I work on Sony TV's everyday and see plenty of cable box HDMI issues. Some of my customers have exchanged their boxes 4 or 5 times and still have HDMI issues. Your best bet is to use the component outputs or switch to Dish or Direct TV, as they DON"T have HDMI problems. If this solution works, be sure to rate it. Thanks!
2answers
I am looking for the paint code of a daewoo nubira 98 sedan. it is not located where it should be on the vehicle. its the green colour
Although Daewoo cars no longer exist, many other dealers have ' taken them under their wing ', locate your local dealer and give them a call and quote the reg number and they will give you any info you want......from your colour code to the radio code. good luck.
1helpful
Colour code for Dark Green Golf 1.4 1997
you can find colour code in trunk of car.pull up carpet look for a white sticker with all the vehicles codes on it .spear tire whel or on round plate to access sending unit.all in the trunk under carpet
Haier HTF20R21 20" TV Logo
Top Haier Televison & Video Experts
Kolbrun...
Paul Bade
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
