Question about Dell Inspiron 6000 Notebook
It will not do any thing. no lights or nothing. Will not start.
Dell inspirion 6000-Will not show any signs of life. I have it pluged in to the wall and nothing. Any ideas where I should start? New charger maybe.
Posted by johnsonkat_2 on
  • johnsonkat_2 Jun 06, 2009
    Thank you. I will try battery first. The charger does have a light on. I will try the battery and go from there. Thank you again.
Anonymous
  • 36 Answers
If no lights turn on or the fan doesn't spin, try removing the battery and checking the pin connectors. You may have bent one and it is not making a proper connection. Could also have an obstruction. If this doesn't work, try replacing the power adapter. But most adapters have a light which tells u if it is working. If it's off...that's your problem. If the adapter works,replace the battery, you may have overcharged it to the point where u killed it completely.
Posted on Jun 06, 2009
Dell inspirion 6000 is showing "loading PBR2.....done. NTLDR IS MISSING.HOW TO FIX
Use the Restoration Disk. When asked choose Repair.
(Non-Destructive Installation)
You are missing basic Windows files. Boot loader files.
Also you may have to prepare to replace the harddrive. May have bad Sectors on it.
Means I would copy off all personal information, after getting that laptop going again, or you may lose it.
Regards,
joecoolvette
http://en.wikipedia.org/wiki/NTLDR
http://computer.howstuffworks.com/hard-disk.htm
http://computer.howstuffworks.com/hard-disk7.htm
Dec 19, 2012 | Dell Inspiron 6000 Notebook
When i start up my dell inspirion 6000 laptop the logo comes up and then screen goes black
When you see the Dell logo, it means the system is booting and you see the splash screen that is generated on the motherboard.
Apparently this is where it is stopping.
Here's what I would do: First when you boot the computer, press F12 to get the boot options. Choose the diagnostics and run the system diagnostics.
You can also try to press F8 to get the computer into safe mode, but I'm thinking if you see nothing other than the splash screen, that may not work. If you are presented with Windows boot options, choose safe mode and do a system restore.
The last thing you can do if you have the Dell system recovery disk is try to do a repair from that CD if it allows you to do so.
Nov 06, 2009 | Dell Inspiron 6000 Notebook
Dell inspirion 6000 a green light flashes and it does not turn on
It's either:
the lcd
video (GPU)
motherboard
lcd cable.
It's really hard to say without being there in person. I'd recommend having a local tech check it out.
Jun 15, 2009 | Dell Inspiron 8000 Notebook
Trying to Wipe Hard drive but Dvd player dosent reconize the disk
Try cleaning the CD, first. If still a problem, the CD may be bad - try in another computer to test.
Jun 15, 2009 | Dell Inspiron 6000 Notebook
Dell Inspirion not recognizing both memory slots
MAKE SURE BOTH SLOTS ARE ENABLED. ALSO MAKE SURE THERE IS NO CONFLICT FOR THEM IN DEVICE MANAGER
Dec 10, 2008 | Dell Inspiron 6000 Notebook
Dell inspiron 6000 drivers or recovery cd for win xp sp2
You need to go to www.support.dell.com and select "I'm looking for drivers and downloads". If you don't have the proper version of Adobe you will be prompted to install it. Once installed return to "drivers and downloads" and enter the "service tag", (serial number) of the 6000 laptop. Dell keeps a listing of drivers for every customer's computer they sell.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 05, 2008 | Dell Inspiron 6000 Notebook
Powers on then off
check it your battery may be it is not properly installed
Jun 10, 2008 | Dell Inspiron 6000 Notebook
Keyboard gone crazy
You can try resating the leyboard once. If the issue is not resolved , then its better to replace the keyboard , otherwise it may lead to motherboard damage.
Apr 14, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
48 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
