I recently installed CUPS. At first everything looked good, the server started and i was able to add printers with the browser or KDE-Control center.
I tried to add an Epson Stylus C86, which is connected at my USB Port. It really looked good too, cups automatically found the printer on the usb-port and suggested the right driver. I added it, configured it and tried to print a test page.
The job was added correctly in the queue but nothing happened. it was just pending there.
I took a look at the error log but there wasnt anything suspicious, so i set the logging level to debug and tried again. After reading through that (now very long) log again, i still wasnt able to find anything false or any error.
Im a bit clueless now, no errors, smooth install and no signs of anything wrong. OR
If You Still Need Assistance Then Follow US For On : Epson Printer Support
SOURCE: Printer hangs up.
1. check the printer, make a copy
2. check connectivity, open device manager - USB Printing Support(under
Universal Serial Bus Controllers) must be there - swap cable/port if
it´s not
3. uninstall, reboot then re install printer driver
SOURCE: Printer will not print, job sits in queue until I
Try this:
>Start menu
>Printers and Faxes
>RT click on the printer > choose properties
>Click on the advanced tab and confirm that the "start printing immediately" is slelected along with "Print spooled document first" and Enable advanced printing feature.
> Click okay try printing a test page
If this does not work then....reinstall your printer driver
In the Print Queue toolbar you have these buttons:
