Home Logo
g
gary horsman Posted on Feb 05, 2014
Overflow tube have replaced fill valve and flapper. done dye test and no water from tank to bowl. fill valve will not shut off no matter how it's adjusted. tried two of them. no water from tank to toilet, not overflowing overflow valve but leaking out somewhere??? and tank doesn't empty over night when water shut off. what...is....happening?
A
Anonymous
If you manually pull up on the float of the fill valve will it then shut off? If it does, most likely your water pressure is too high, should be around 60 psi. More then 80 and it won't shut off. You may need to add a restrictor to the fill valve. Most fluid-master units come with one already installed, you could try one of them.
2 Related Answers
Anonymous
  • 81 Answers
  • Posted on Sep 29, 2010
SOURCE: Just installed the cadet 3
The amount of water in any toilet bowl is determined by its construction and no tank adjustment will ever change that. American Standard has a history of having small water surface areas in their low or ultra low flush toilets. Take a large container of water and pour directly into the bowl. If the ending level remains the same, then that is the manufactured level for your toilet.
Not all tanks completely discharge all of the water when flushed. Measure 1.5 gallons of water into a container. Turn off your water supply to the toilet then flush normally. Replace the water in the tank with your premeasured amount and observe this new water level. You might be surprised to find it is at the same level it always is. Since water weighs more than 8 pounds per gallon, one concept used in todays toilets is to have more than 1.5 gallons of water in the tank and use the extra weight push the water past the flapper at a faster rate while designing the flapper to drop after only 1.5 gallons have passed through.
Testimonial: "Thanks. Looks like I will be taking this one back to HD. I have heard that the Kohlers are pretty good, any thoughts on them?"
Anonymous
  • 22 Answers
  • Posted on Mar 05, 2011
SOURCE: Eljer 0220 toilet leaks from tank to bowl, then
Hi,I have spent then past 13 years doing maintenance work and have seen this a lot. First the flapper could be warped even if new might try replacing.Second you will need to replace the the fill valve with new,I recomend Fluidmaster brand.
Water keeps filling in toliet even after full
hi Patricia.
Overview Toilets haven't changed much in the last 80 years. After a flush, water still fills a tank, lifting a float that shuts off the water when it reaches a certain level. A lever still opens a flapper to cause the flush, falling back into place when the water level drops. So it's no surprise (nor any consolation) that we face the same flush problems today that our grandparents did. Sometimes the flush is too wimpy, sometimes the toilet keeps running, and sometimes the bowl doesn't refill.
Our ace plumbing consultant has a simple four-step strategy to solve 95 percent of these problems. You can complete the first three steps in five minutes. That'll solve most problems. The fourth step is usually easy too, but not always. More on this later. These steps work for most toilets but not for pressure-assist models.
Check the fill tube
Overflow tube problem
Push the fill tube firmly onto the fill valve. Make sure the fill tube sends water into the overflow tube.Remove the tank lid and find the fill tube. It's a small flexible tube that runs from the fill valve to the overflow tube. While the tank refills, this tube squirts enough water down the overflow tube to refill the bowl after the completed flush. If this tube falls off or the water stream misses the overflow tube, the bowl won't fill and your next flush will be wimpy (that is, won't develop a strong siphon). Reattach the fill tube and make sure it perches about 1 in. above the rim of the overflow tube. Flush the toilet and watch the water stream to make sure it goes down the overflow tube.
Adjust the fill height
Check the float
Adjust the float to set the water level. Pinch the clip and slide the float up or down on the rod. Keep adjusting the float until the water shuts off at the proper level.The water level in the tank is controlled by an adjustable float. A float that's set too low produces a weak flush; if it's set too high, water spills into the overflow tube and the fill valve won't shut off. The toilet keeps running. Look for the fill level mark on the inside back of the tank and mark it on the overflow tube so you can see it more easily. If you can't find it, measure down about 1 in. on the overflow tube and make a mark. Then flush the toilet and see if the water reaches and stops at that mark. If not and the toilet keeps running, adjust the float up or down. If you have an old toilet, you'll have to bend the brass rod that connects to the float ball to make adjustments. But with newer toilets you usually turn a screw or slide a clip along a rod. Flush the toilet after each adjustment.
Also make sure that the water level is at least an inch below the C-L (critical level) marked on the fill valve. You can adjust the height of many valves to raise or lower the C-L.
Occasionally the fill valve simply won't shut off, which means that it's defective. If so, turn the water supply off at the shutoff under the tank. Buy a replacement valve (sold at hardware stores and home centers). You don't have to match the old one; many, like the one shown, fit most toilets. It's a 15-minute change-out.
Adjust the flush handle/flapper chain
Flapper chain fix
Adjust the chain to leave a little slack with the flapper closed. Then cut off the excess, leaving about an inch.A chain that's too short or tangled won't allow the flapper to close and water will continue to leak into the bowl. This causes the fill valve to cycle on and off to refill the tank. A chain that's too long, or a flush rod that hits the the tank lid, won't open the flapper wide enough to stay open for the full flush. You'll find yourself having to hold the lever to complete a good flush.
To avoid these problems, adjust the linkage in the chain to leave only a slight bit of slack when closed. Cut the chain at the rod to leave only about an inch extra to reduce the potential for tangles. Then put the tank lid back on and make sure the flush rod doesn't strike the lid when you press the lever. If it does, bend it down slightly and readjust the chain.
Replace the flapper
Change the flapper
Unsnap the old flapper and take it with you to the store to find an exact replacement. In addition to the closest replacement, pick up a "universal" type.If you've completed the first three steps and your toilet keeps running, chances are you have a worn-out flapper. Turn off the water, remove the old flapper and take it to the store to find an exact replacement. (Hardware stores often carry a wide variety.) Most flappers snap over ears on the overflow tube. Others have a ring that slips over the tube.
Now here's the catch. You may not find an exact match. The range of flapper styles has mushroomed over the last 15 years, and you may find 15 to 20 flapper options on the store shelf. Some packages include specific brand and model information (so note yours before you leave home). Others have a "universal" label. If you can't find an exact replacement, try the closest one and pick up a universal type as well. They're cheap, and the extra one just might save you a second trip to the store! (Avoid the "adjustable" types unless you're replacing an adjustable one.)
Install the new flapper and make sure it opens and closes freely. Then test it. If the toilet keeps running or runs intermittently, you're not getting a good seal. Try a different flapper if the toilet won't stop running.
If you just can't find a flapper that seals, consider replacing the entire overflow tube/flapper. On most toilets (two-piece), this means removing the tank. It's not difficult and you don't need special tools. It'll take you about an hour, and you'll avoid that expensive plumber service call.
if you go to this link it will show you step by step on how to fix it. How to Stop Running Toilet Family Handyman
Nov 27, 2017 • Home
Loosing water from insulated crane toilet tank
The fill tube may have a crack in it. I am referring to the plastic tube where the water runs in from a small rubber tube connected to the fill valve to refill the bowl after you flush it also serves as an overflow tube in case the water level gets too high. a crack will allow water from the tank to run into the bowl bypassing the flapper. checks this and replace if necessary. hope this helps.
Bob
Have a fluid master valve--I believe it is a 883B--fills the toilet and appears to shut off but very slowly keeps filling. Never actually shuts off completely..Please Help!!
there are only 2 possibilities; 1 the tank seal is leaking into the bowl and the input valve runs to replace the water lost, or 2, the water inlet valve does not shut off totally and the water continues to flow into the bowl via the overflow tube in the tank.
If the water is running into the overflow tube, adjust / replace the input valve, if the water is not going into the overflow valve, clean / replace the flapper valve at the bottom of the tank.
Please let me know how you make out.
Aug 25, 2011 • Home
2answers
Korky anti-siphon. Tank water slowly drops, accompanied by a hissing sound. Then, after dropping about 1/2 inch, it refills. Wha?
either the fill valve is running and water is draining into the bowl via the overflow tube in the tank or the flapper is bad (or foreign matter) and it is allowing water to escape into the bowl slowly...causing the fill valve to run every few minutes or so. hope this helps but if you need anything else just text me here:)
4helpful
Tank is full but continues to fill for a minute or so every so often. Ethan Annis [email protected]
either the fill valve is running and water is draining into the bowl via the overflow tube in the tank or the flapper is bad (or foreign matter) and it is allowing water to escape into the bowl slowly...causing the fill valve to run every few minutes or so. i just sent this to your email too. hope this helps but if you need anything else just text me here:)
Jul 28, 2011 • Kohler Home
When my elder tank fills up once in a while it will loose water from the tank without a flush. The water will come on for about five seconds to refill. What do you guys think the problem is?
It's the Flapper or Flush Valve. Get some green or red food coloring and a flashlight. First remove the tank lid and lift the seat and cover up against the tank. Take your flashlight and shine it on the back of the bowl, where the water line is. if you can see water coming down the back side of the bowl and disturbing the calm water ie. making ripples. ( be patient and watch carfully). If you can see the water being disturbed most likely its the Flapper. Now take your flashlight and point it down into the flush valve fill tube. That's the thing that looks like a pipe standing up in the center of the toilet tank coming out of the water about an inch or so. Look for water very slowly pouring into this tube from the inner walls.look from the top all the way to the bottom of the tube. If you see water leaking into the tube you need to replace your "Flush Valve". That's another post... If not, then most likely it's the "Flapper" put the seat back down and sit on it facing the tank. Reach into the tank and lift the flapper up and feel with your fingertip the flapper seat by circling the seat. Like you would a glass rim to make a tone with it. If you feel a nick anywhere on the seat you will need to repair the flush valve flapper seat. If not then you need a replacement flapper. If you cant see/find any of the leak problems as mentioned above then it's time to use the food coloring. Add it to the water in the tank. DO NOT FLUSH ! Let the dye mix with the water and then start to inspect the areas as mentioned above. ( Back of bowl/water line and the fill tube in center of tank). Use the flashlight to find the colored water in the areas as mentioned. Before making any repairs turn the water off to the toilet. PARTS: FLUSH VALVE REPLACEMENT If you need to replace the flapper seat flush valve. Because you found a nick in the seat rim, FLUID MASTER makes a great repair kit for that. Follow their instructions. Hint: Make sure the existing seat is dry before installing the fluidmaster repair kit. Also you get one shot at it. The adhesive is strong you wont be able to pull it back off once you install it. FLAPPER REPLACEMENT Take your old one with you to Lowes/Home Depot and match it up. Hint: Once you put the flapper on, take out most of the slack in the flapper chain when you connect it to the flush handle. once you're happy with testing the dry flush cut the remainder of the chain off with **** ( wire cutters). If the problem is a cracked overflow tube you'll need to replace the flushvalve assembly. If so you may email me at [email protected] and we'll go over that prosess on the phone if you'd like. I hope this helps. Good luck, Mike. ps. Don't forget to click on the hyperlink above for a cut away view of the toilet tank.
Dec 23, 2010 • Eljer Home
The water in the bowl keep runing after the tank is full.
fill valve not shutting off water running over overflow tube set or replace fill valve flapper valve leaking replace flapper valve cracked and leaking flush valve assembly replace
2helpful
2answers
Toilet tank looses water over time
As long as there is no water leaking from the tank to bowl connection, you are OK. You would know if it was leaking here, because you would have water dripping out onto the floor.
Verify that the water level in your tank is below the top of your new flush valve's overflow tube. If the water level comes to the top, it will overflow into the toilet bowl. This can be easily fixed with an adjustment to the fill valve.
If the water is not overflowing into this tube, then the only way you can lose water is through the flapper. You said you changed the flush valve, which would have come with a new flapper attached to it, but maybe buy a new flapper and see what happens???
2helpful
2answers
Tank not holding fill level...
Most likely, you do not have a good seal on the flapper valve at the bottom of the tank. To confirm, try this:
Turn off water and flush toilet. Then lift up the flapper valve and put a light coating of vaseline on the mating surface where it contacts the toilet tank when closed.
Turn water back on and see if it continues misbehaving. If that fixes it, it was a bad seal. Usually that is all it takes.
2helpful
Is there a manual. The water keeps running.
the fill valve shut off level setting is too high. water in the tank is overflowing in the overflow tube. adjust fill valve to shut off at lower tank level
Top American Standard Home Experts
john h
Mike Cairns
Mike Cairns
deton8 von Splosion
Are you an American Standard Home Expert? Answer questions, earn points and help others
