Question about Brother MFC-7340 All-In-One Laser Printer
Drum Error Suddendly stpo printing due to drum error
Posted by angamalik on
Printer Help & Support
  • Brother Master
  • 783 Answers
Sir/Madam
Go To Below official Brother Printer Page For Your problem, DRUM ERROR Brother
Hope It's resolve all Your HP Printer Problem,
Or
Still having Problem Then follow Us For
Brother Printer Support
Posted on Feb 06, 2014
3 Related Answers
57 varieties
Karl Wright
  • 1653 Answers
SOURCE: drum error
Do the following
Posted on Oct 17, 2009
skperform
SOURCE: Brother 4070 CDW Drum Unit Error
The green tabs that you have to slide are under the color cartridges, so remove the three color cartridges and you will see three green tabs, to slide the tab across the wire you have to first open the translucent plastic wire cover, then slide the green tab across the wires and return it to it's original position, close the wire covers, replace the color cartridges, and reassemble the printer. All the Best
Posted on May 03, 2010
Anonymous
  • 241 Answers
SOURCE: Drum error message
To reset MFC-7840W drum count use the following steps.
1. open the front cover (leave open).
2. Press clear/back.
3. Then confirm the new drum install by pressing 1.
4. The display will indicate accepted.
5. Then close the front cover.
This should be done each time the drum unit is replaced.
Posted on Jun 18, 2010
Testimonial: "Yes it worked! thanks "
Drum light indication and error light indication is on
Hello, Sounds like you need a new drum or maintenance kit for the laser. You need to call your maintenance provider for repairs or take to a computer/office supply repair shop.
PRINTER DRUM ERROR
The drum unit needs to be replaced as it has reached maximum prints for the drum.
The drum unit is the carriage part that the toner unit sits in before it is put in the machine.
How to reset " replace drum" for brother MFC-7860DW
Time to really order a new drum and really replace with a new one.
Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
2.Replace the drum unit and toner cartridge into printer.
3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
4.To clear this error message, you need to reset the drum counter as instructed below.
5.Make sure that the machine is turned on.
6.Press Options.
To confirm you are installing a new drum, press 1.
7.When the LCD shows Accepted, close the front cover.
8.Your drum is now reset.
Drum error dr-420
Sir/Madam
he following error messages will continue to appear if the drum counter was not reset when you replace the drum unit with a new one.
  • Replace Drum
  • Drum End Soon
  • Drum Near End
  • Drum Stop
To clear these error messages, you need to reset the drum counter,
Or Visit official Brother Printer website For Brother Printer Troubleshooting Page Url Below:http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/002800/000037/faq002837_000.html?reg=us&prod=mfc7340_us_as&c=us_ot&lang=en
Or
Still Having Problem then follow Us On For
1helpful
2answers
Canon irc 3080i error code e000020-0023
NITIAL FAULT IS ERROR CODE DUE TO WORN BLACK DRUM GIVING PATCHY IMAGE, ON FITTING A NEW DRUM IT CREATES ANOTHER ERROR CODE ABOVE E020, ON RE-FITTING OLD ONE ERROR DISAPPEARS. PATCH CREATED ON ITB IS UNDERTONED DUE TO LESS INTENSITY LASER BEAM PASSING THRO, THE RESIDUE ON THE GLASS, HENCE E020-0023.
THE CLEANING TOOL ON THE DOOR IS INADEQUATE TO CLEAN THIS RESIDUE. PULL OUT PROCESS UNIT TO MAX. LIMIT. PRISE UP THE DUST SHUTTER, THEN CLEAN WITH DAMP WIPE AND DRY IT. REPEAT IF NECESSARY OR TAKE LASER UNIT OUT
It has come up drum error, i have cleaned the laser pinter window screen as well as the cornora wire yet it still comes up with drum error? help me please
Your drum has reached the end of its life. You either need to reset the drum or buy a new one. If you reset the drum (you can find instructions on the web) and then notice poor print quality you need to replace the drum to correct the print quality.
25helpful
Will not print the error light and the drum light flash. Replaced drum but still will not print and error light and the drum lights still flash.
The drum counter will have to be reset, Use the following steps.
1. Open the front door.
2. Press and hold the cancel button (x button) until all the lights flash in in order.
3. Then close the front cover.
This will reset the drum counter so that you can continue to print.
68helpful
Drum error message
5helpful
5answers
RZ 220 Risograph error code A-16-525 after paper jam indication. No jam was present.
The master is stucked on the print drum,open print drum remove master and try again.
Let me know for futher help.
3helpful
2answers
Error E100
The most common cause for E100 is the drum unit. At the rear of the drum unit should be a small peg pointing into the machine. This gets broken off. It's purpose is to opperate a laser cut off shield when the drum is removed so to prevent laser exposure. If peg is missing laser will not be detected by the system and give E100. Can be repaired or will require a new drum if it has done more than 40 to 60K copies.
Brother MFC-7340 All-In-One Laser Printer Logo
Ekse
k24674
