Question about Brother DCPJ125 All-In-One Inkjet Printer
Troubleshooting oh printer
My brother printer show on screen unable to print 4f
Posted by Kristoff Suarez on
Printer Help & Support
  • Brother Master
  • 783 Answers
Look in the user manual under errors or go to the Brothers support website and look up the model and error codes.Brother Printer Support
Posted on Feb 06, 2014
5 Related Answers
livetech
  • 583 Answers
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Posted on Jul 13, 2009
Anonymous
  • 787 Answers
SOURCE: troubleshooting : unable 4f cant print
Error 4f mean the head drive voltage has dropped from the high to low level in an abnormally short period.This mean your printer need new print head.This will cost you just as a new printer, then think about new printer.
Posted on Nov 04, 2009
pineworks
Clive
  • 4345 Answers
SOURCE: Print Brother Mfc-290c Error Print unable 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 18, 2010
pineworks
Clive
  • 4345 Answers
SOURCE: brother mfc5860cn has error message print unable - 4F
Hi there
Please try this.
Posted on Mar 02, 2010
pineworks
Clive
  • 4345 Answers
SOURCE: Unable to print 4F error message
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All files on my website are only there for a limited time
Posted on Apr 25, 2010
How to fix Brother printer J415W with error message "Unable to Print 4F
The printing process is blocked by a system problem, indicating the Brother Printer In Error State Windows 10. Normally, this problem is caused by system permission settings, corrupted drivers, or system conflicts.
Solutions of Brother Printer In Error State Windows 10:-
1. Make ports settings changes.
2. Make sure that your printer is Online.
3. Reinstall the printer driver.
4. Set the Print Spooler service to automatic.
5. Update Windows.
If the problem continues, check this blog or call Printer Support to stop more printer damage.
Solution with Expert Advice- Brother Printer In Error State Windows 10
Jul 30, 2016 | Brother MFC-J415W Multifunction Inkjet...
Printer not printing
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_440CN_665CW_845CW_EN_287.PDF
Under the troubleshooting section(pg.154) it lists this error as having one of two possible causes:
just do CTRL plus f to find
Unable to Clean XX
in the pdf document
As you failed to mention the model number it may not be your model number but the basic principal will be the same on the cause.
Jun 10, 2016 | Brother DCP Office Equipment & Supplies
UNABLE TO INIT 4F BROTHER DCP-195c CAN'T TO PRINT.LCD SHOW UNABLE TO INIT unable 4F. my brother printer when on the screen show unable to print. how to solve the problem ?
The printer have its own initialization but seem to fail to complete initialization process. Check and clear the carriage jam, open check for motor failure in the carriage system.
Dec 18, 2015 | Brother DCP-195C Inkjet Multifunction...
Unable to print 4f
good day, unable to print 4f is printer head problem...replace new printer head
Apr 09, 2014 | Brother DCPJ125 All-In-One Inkjet Printer
UNABLE TO INIT 4F BROTHER DCP-J125
my brother printer when on the screen show unable to print 4f
model printer brother dcp-j125 how to solve the problem ?
Dec 16, 2011 | Brother DCPJ125 All-In-One Inkjet Printer
Troubleshooting : unable 4f cant print
Nov 04, 2009 | Brother Multi-Function Center MFC-240C...
Jul 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
Error message ''Unable to Print 4F''
How to repair error "print unable 4F" in the Brother dcp-135c .
thank alot.
Jan 06, 2009 | Brother MultiFunction Center MFC-440CN...
Brother DCPJ125 All-In-One Inkjet Printer Logo
43 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
