Hi expert, i have peavey PV20 mixing board, and planning to records our instruments and vocal (songs). but when i put it in usb cable in my laptop, its not recognizing it "Audio codec driver not found". can you please help in this matter. thanks in advance and God bless!
SOURCE: run a sub woofer to a peavey board
I would recommend using a separate active crossover such as the Peavey 23XO and a separate amp for your subs.
SOURCE: circuit diagram for a Peavey 130 special
Try http://www.peavey.com/support/contactinfo/ You may be able to get one from them. When I was doing repairs they would only release schematics to Peavey dealers but you can always ask.
SOURCE: Our Peavey 32fx is not recognizing the memory
I wasn;t able to get a manual to download, however, a lot of these things MAX out at a 2Gb stick. If you try using larger, I suspect that might be the problem.
Blogs seem to indicate that the sticks are LESS than reliable and one has to remove a lot of effects due to CPU throughput being insufficient.
Make sure your memory stick is less than 2Gb
SOURCE: how do i connect the cables between peavey vocal
if you mean effects loop try graphic out to ultraverb input and output to power amp in. this will effect all channels of the xr500c
