Howl to fix air condition on 1997volvo960 air only blows to floor
You probably notice that it blows through the dash UNLESS you accelerate hard, then it's floor and defrost vents that gets the air.
It's a ~$40 dual action bellow sort of up over the gas pedal that is malfunctioning. You can put a band-aid on it by removing the kick panel over the pedals and then plugging the yellow line going to the bellow.
To replace it (per Volvo) you have to remove most of the dash! That's expensive and a pain in the behind, plus you probably will have rattles in the dash after.
OR you can cut a hole in the air box where the baffle connects and replace it, then patch the hole with the 'lid' you cut out and duct tape it back on.
Nobody will ever see it. :D
