Question about KLH DVZ-2500 System
How do i reset the passord on my computer the
How do i reset the password on my computer the admintration password
Posted by michelle_85 on
Anonymous
    New Friend:
    Problem Solver:
  • 7 Answers
3308 or 2001
Posted on Feb 13, 2010
Athouba Sanasam
  • 122 Answers
Click start then run then type cmd, on the command primpt type (net user administrator * )then enter
type a new password
and confirm it then your password is changed to a new password.
Posted on Sep 11, 2009
Anonymous
  • 34 Answers
When u turn da pc on, keep pressing f8 until a menu comes up den click safe mode and u should be able to reset ur admin password. I hope dis helped =)
Posted on Jul 17, 2009
How to remove password
which password, power on password or o/s password?
if its power on password you need to reset BIOS. by removing the coin cell battery on the motherboard together with a jumper just next to the coin cell. its called CMOS. Power on the computer and all the bios settings will be reset including the passsword. if its o/s passord that is created in the control panel you need to use a software called password xp.
Oct 04, 2013 | Computers & Internet
Need to reset my password
Rogers reset your password to what? What do you need to change the password for?
Jan 23, 2013 | Microsoft Computers & Internet
Need to reste my password
Rogers reset the password to what? What do you need to change the password to?
Forgot my windows ce password need to rest my laptop back to factory setting
Forgot windows password, we can use Windows Password Reset to reset our windows password.
The steps are:
Step1:Download and install Windows Password Reset from http://www.windowspasswordreset.net
Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB.
Step3:Put in your newly created CD and remove your Windows Password
So easy,right?
Jul 08, 2012 | Computers & Internet
Forgot user password
I met the same difficulty for the previous period,and I know the easy
and effive method that you can use Windows Password Reset to solve it by the Internet,while the use method is following.
Tip1:Download Windows Password Reset from windowspasswordreset.net and install it on your computer.
Tip2:Burn Windows Password Reset to CD/DVD or USB.
Tip3:Insert newly created CD/DVD or USB to your computer which you forgot its password and reboot it,and follow the instruction that follows.
I hope you can reset windows password soon.
May 21, 2012 | Advent Computers & Internet
I just changed my password and user name to be able to get into my Netgear settings and I have some disabilities so I quickly forgot my password so when I went to try it wont let me in the initial type in...
very sorry to say but yes the Old admin and passord is not gonna Work now
Only way is to HARD RESET the Router with the Reset Hole behind router for 30 secs or More
then again Reconfigure the Wireless
All the BEST
Oct 07, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
I have dell Desktop t3400 pc i will go start them its ask passord not a windows passord before windows satrt ask password. What will i do
It is bios password for that you have to reset *********** bord bios to defaults.
open cpu cabinet and then find CMOS cell on motherbord.
It is like round battery cell.
Then pull it for 10 minutes from motherbord then again refix it in it's position then it not ask for password.
Let me know if you need more assistanse.
Thanks.
Sep 26, 2009 | Dell Precision T3400 375W 32bit Computer...
Have a problem whith a bios passord the pc system is #dvxnq2j-595b
if u have forget the bios password nothing can b done....bios password can only b reset by removing the c-mos battery...or else install a new os..
May 22, 2009 | Dell Latitude D620 Notebook
NORWEGIAN: PASSORD P? EPOSTKONTO
Du kan ha skrevet inn feil passord første gang du setter den i, så det er å huske feil passord hver gang.
Prøv å fjerne merket "lagre passord" og sjekke e-post, legge i riktig passord, og deretter merker du lagre passord og se om den gjør dette neste gang du sjekker.
Vanligvis feil passord ville forårsake problemet du har. ENGLISH: You may have typed the wrong password the first time you put it in, so it is remembering the wrong password each time. Try unchecking "save password" and then check e-mail, put in the correct password and then check save password and see if it does this the next time you check. Usually an incorrect password would cause the problem you are having.
Dec 18, 2008 | E-Machines eMachines Desktop PC
How to..?
You will need access to the router. Press and hold the “Reset” button for at least 10 seconds, then release it. The lights on the Router will momentarily flash. When the Power/Ready light becomes solid again, the router has been reset. To access the routers web page, in your browser, type 192.168.2.1, in the login screen, leave the password blank and click the “Submit” button to log in.
Once you have logged in, be sure to go to “System Settings” page where you can enter a new administrator password.
Good Luck!
Aug 09, 2008 | Belkin (F5D7230-4) Router (587009)
KLH DVZ-2500 System Logo
122 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Vincent G
Vincent G
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
