Question about Toshiba 26HF85 26 in. Television
Help HDMI Splitter Doesn't Work!
I have a Sony Bravia Television. There's just one hdmi input on the back so I got a Phillips hdmi splitter. When I connect a Dish network hdmi cable PLUS a PS3 hdmi cable into the hdmi splitter it doesn't work. When each cable is plugged in individually the tv works fine
The HDMI splitter is intended to take one source to two displays. You need an HDMI switch to take two sources to one display, a device you can tell which input to select.
Posted on Jul 08, 2009
    New Friend:
    Problem Solver:
  • 10 Answers
Have you tried some other hdmi splitter, its a problem with your hdmi splitter I suppose. Try KVMSwitchTech's <a rel='nofollow' href="http://www.kvmswitchtech.com/hdmi-splitter-c11622.htm">HDMI Splitter</a> units, these are cheap, highly durable and comes with 1 year warranty.
Posted on Aug 09, 2012
    Problem Solver:
  • 14 Answers
Http://www.kvmstuff.com/video-routing/video-splitters/hdmi-video-splitter.html
is that transfers signals from single source to multiple destinations.
Posted on Aug 12, 2009
  • luecjennifer Aug 12, 2009
    there's a difference between hdmi splitter and hdmi switch, you need to find out what you really require, rather than what you have.
I need help setting hooking up my DVD player to my hisense tv
There are 3 options for connecting a DVD player to a television. HDMI, Component or VGA. The most common, and best, these days is HDMI which requires 1 cable, called a HDMI cable, between the player and television. These input / output sockets are clearly marked & there is usually about 3 of them on most televisions. HDMI 1, HDMI 2, HDMI 3. The next is component. These consist of 4 separate connections. RED, GREEN, BLUE & YELLOW. Again simply connect like to like. The third (VGA) are RED, WHITE & YELLOW. Same deal, simply connect like to like on player and set. Once one of the connections are made select SOURCE on the television remote and select the connection that you have made. Cheers
Dec 14, 2016 | Televison & Video
On my LT42HVi with HDMI input source, the image comes through with a lot of green then will change back to normal color. Switching cables or HDMI input port makes no difference. Using normal TV inpu
is the normal tv input for high definition? Don't understand that term. I have a dish receiver, when I use an hdmi cable I get a really nice picture even with Roku
Jan 02, 2015 | Olevia LT42HVi 42 in. LCD Television
I have no signal,what can I check?
OK Joan,, I might need more info. not getting signal could be caused from several things.. one make sure the Dish Antenna is mounted correctly, (level, and true, [one degree off on earth is like 700 miles off at the Satellite.]) check you cables and make sure they is now wire touching the center core of the coax. if the coax has splitters, connections etc outside check for the corrosion inside the threads.
make sure the coax coming into the house is connected to the right place on back of the 222k. make sure u are on the right Video stream for the HDMI. are u getting any picture showing the Dish set up or is the screen all Blue.. if it is blue try to use the remote that came with ur TV (RCA, Vizio, Phillips,,,,etc) and look for the input, source , or Antenna button and push it to match your HDMI input..
Oct 28, 2014 | DISH Network Vip 222k Hdtv Satellite...
How do I cable this connection please?
It depends what input connection the second TV has available. You cannot directly daisy chain HDMI cable from Apple TV to the two TVs assuming both have HDMI input. But you can purchase an HDMI 1x2 splitter and connect the 3 up provided the 2nd TV also has HDMI. The challenge maybe the distance you can have between the two TVs. Max is 15 meter but you could cascade 2 units to create longer distances.
http://www.ebay.com/itm/HDMI-Splitter-Box-High-Speed-Full-HD-1X4-4-Port-Hub-Audio-Video-1080p-Amplifier-/191120909726#ht_2675wt_1337
Apr 28, 2014 | Televison & Video
I have a Denon avr-3808ci. I have a Dish Network DVR and a Sony KDS-60A2020 tv. If I connect the HDMI cable on the DVR directly to the tv, I get picture and sound through the tv. If I connect the HDMI...
You are correct. I feel your pain. This will not work.
HDMI is a pure digital signal and the providers require the content coming over the Dish DVR to be COPY PROTECTED. So it will not work unless the HDMI cable goes directly from the DVR to the TV. This is to stop people from being able to make their own recordings of Dish shows, or making copies of your DVR recordings. If you really want to run things through your reciver, you're going to have to use the "component" or "composite" video feeds, not the HDMI. Sorry.
Sep 18, 2011 | Denon AVR 3808Ci Receiver
I HAVE A 32A41 TOSHIBA TV, THE SERIAL NUMBER IS 55678997.... TAC 0101, AND IT WAS WORKING FINE AND ONE DAY A PERSON TOOK THE REMOTE CONTROLL AND TAUCHED SOMETHING AND THE PICTURE WENT AWAY AND I...
We would be happy to help get that fixed right away. Theissue that you are having sounds like it is affecting the TV that is closest toyour receiver; we call it your TV1. The first thing we want to ensure is thatall connected equipment is on. Check what type of cable is used to connect theTV to the receiver. If you are using a Coax Cable to connect the receiver toTV1, check the receiver's back panel for the output name. If your receiver hasa "TV CH 3/4 Out" (non-ViP Receiver): Tune TV to channel 3 or channel4, back if it is labeled "Home Distribution" (ViP Receiver):Tune TV to channel 62 or 75. If using non-Coax (RCA, Component, or HDMI) toconnect receiver to TV1, cycle through the inputs until picture appears; MostTVs have a "TV/Video", "Input", or "Source"button. We want to ensure that the TV and the receiver are connected properly,please visit this link to for more information:http://www.dishnetwork.com/SupportSection/setup-receiver-totv. Once we havemade sure everything is connected properly, unplug receiver for 10 seconds thenplug it back in, this will reset the receiver. If we are still not getting apicture connect another component (VCR, DVD Player, etc.) to the same TV, usingsame cable, same input, and same channel to see if it works. If you get apicture with the other component give us a call at 1-800-333-DISH (3474) forsome additional troubleshooting. If it doesn't work with the other componentthen replace the cable that was used.
We hope these steps resolve the issue. We want to thank you for being a valuedDISH Network customer!
Phillip Chang DISH Network Customer Service Representative
Jan 02, 2011 | Toshiba 32A33 32" TV
HDMI 1 imput keeps jumping to TV input
I assume you are connecting a Dish Network receiver (model?) to your Sony TV with an HDMI cable. I also assume this happens daily. At a certain time (default 3AM but changeable) the Dish receiver (modern models) will reboot and the "screensaver" it normally outputs will be turned off for a minute or so. Some TVs, in obeying the rules for high definition connection (HDCP) will unlink their connection. Some are fussier than others and some will not automatically recover on power up. Since the Dish receiver must reboot to maintain its stability and then refresh its guide, you should be able to do this if the TV is turned off overnight.
If you still cannot get the connection maintained, I recommend that you connect with component cables--RGB+RW cables (the red-Y, the green Y=luminance, and blue-Y signals and audio right and left.) You may have to select a different input before turning the TV off, or maybe just changing source input will recover the one you want. I have no problems with my VIP722 receiver and my Samsung DLP TV. You might be able to get some more specific advice from the www.AVSforum.com message board for you TV.
-Ken
Apr 16, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My dish 322 receiver wont work 2 tv,to get service
  • There are two satellite inputs on the back of a 322. There may be a single cable going to a splitter connected to these two ports or two individual cables.
  • If there are two cables swap them, if you still get signal on the same input only then the receivers input is dead.Otherwise follow the bad cable and ensure it is not damaged or disconnected. Swap the location on the other end and see if the issue stays on the same cable. If so replace the cable, if not replace the LNB or Switch.
  • If there is a splitter bypass it and connect the single cable directly to the input that does not work. If there is no signal the port is bad, replace the receiver. If there is signal then reconnect the splitter, press menu 6-1-1, check switch, and then test. Allow the test to finish. If the two inputs do not match replace the splitter... Its called a DP Seperator
Jan 24, 2010 | DISH Network 322 DTV Receiver
HDMI splitter audio drop-outs with Sony Bravia HDTV
Loose the splitter and you will be in good shape unless there was damage done you should be good.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 15, 2009 | Toshiba 26HF85 26 in. Television
No sound when my computer is connected to my Sony Bravia TV
If your computer has a svga output use input 7 on tv with vga to vga cable and 3.5-3.5 Radioshack 42-2387 cable for audio for best results. If you use the dvi to hdmi on input 6 on tv use 3.5- rca Radioshack part number 42-2551 1/8=3.5mm.
Apr 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Toshiba 26HF85 26 in. Television Logo
1,975 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
