Hi I am trying to connect the Digitech usb to ethernet adapter to my Kogan android TV dongle. It accepted the ethernet on my first attempt but then stopped working after that. Does anyone know if the Digitech adapter need the seperate power supply,I can see a power port but the product didn't come with cord and power adapter.
That usb is usually for keyboard or mouse, interesting that you got it to work. It would depend on if android has a driver for the Ethernet adapter built in. Any reason why you are not using the wifi?
Testimonial: "Thanks Mark, with wifi I found online streaming of TV is bit slow, using ethernet it gets smoother. The dongle suopports and has a driver for ethernet connection using USB adapter. I am not sure though if the dongle is able to supply the 4.2 to 5.5V operating power required for the usb ethernet adapeter."
SOURCE: HPNA setup
all you need is the longitus eterneth cable needed to connect to / from the Dynex 4 port Hub ethernet cable plus a host pc on Dynex 4 port ethernet hub, the host pc you need to specify that you are sharing the connection of internet connection through the eterneth, and ready
luck
SOURCE: I have USB 3G wireless modem but want to use the
Yes, Proxicast makes a device called the PocketPORT Cellular Modem Bridge which is specifically designed to connect a 3G USB modem to any Ethernet port.
http://www.proxicast.com/shopping/index.php?target=products&product_id=29891
SOURCE: f5d5050 Belkin USB 10/100
You cannot install this adapter in a Win 7 computer because the drivers are not compatible with Win 7.
So far Belkin haven't updated the drivers for win 7 OS. The latest drivers for this adapter is compatible only with
" Windows 98SE, Windows Me, Windows 2000, Windows XP 32-bit, Windows Vista 32-bit "
Click here to see the belkin compatible drivers in the website.
With Regards,
Prema.
