There are only two things that I can think of, both related. 1. The drum is turning with difficulty. 2. The drum is dropped down in the cabinet letting the belt be loose. Open the dryer door and feel around the opening just inside the opening. Feel for the felt seal. Is the gap even top and bottom? My guess it's not. If not, he top part which is the support for the front of the drum is worn out, letting the drum tip down and loosen the belt. Check the rear bearing. With the belt loose, pull up on the back end of the drum. Does it move up and down in the bearing. If it does the rear bearing needs replaced. Both are simple to do.
