Question about Rotel New Original RR927 Remote Control
Rr-927 does not work - Rotel New Original RR927 Remote Control
Which other TCM number can match my transmission, this is the number 01M 927 733 HJ
Its best to use the one that came with the car because the computer send a codes to the engine
http://www.ebay.com/itm/VW-GOLF-MK4-1-6-AEH-SIEMENS-AUTO-GEARBOX-CONTROL-UNIT-ECU-01M-927-733-HJ-/331739120850
Jul 29, 2016 | Cars & Trucks
Hobbymatic 927. How do I clean and oil?
Pfaff - Machine Support
www.pfaff.com/Support-and-Updates/Support
help is here. Whether you've simply misplaced your manual or you require a more creative solution, you're in the right spot.
Sep 08, 2015 | PfaFF Sewing Machines
SPEED ERROR ON PRECOR 927 TREADMILL
I had the speed error on my precor 9.23. When I opened it up I found that there are two little round magnets on the belt pulley with a sensor mounted nearby. This must be how the computer know the speed of the treadmill. I noticed that there were several little metal shavings stuck to the magnets. Not sure where they came from, hopefully not another problem. However, I removed the metal shavings from the magnets and everything worked fine again. If anyone else has the speed error it might be worth a look to see if its the same problem.
Jul 02, 2012 | Precor 927 Treadmill
What is the 6DO 927 613 for on a 1998 volkswagen passat
is this a part number you have copied of the car?
Mar 18, 2012 | 1998 Volkswagen Passat
Only two speakers will work on my dell dimensions 2400. Trying to use the Kinyo ta-927 surround speakers
HAVE YOU GONE TO THE CONTROL PANEL AND SET IT UP IN SOUNDS AND AUDIO THEN GO TO SPEAKERS ON THE SOUND TAB AND GO TO ADVANCED AND MAKE SURE IT'S SET UP FOR SURROUND SOUND .....OK
Jul 09, 2009 | Kinyo TA-927 Computer Speakers
Rotel New Original RR927 Remote Control Logo
Top Rotel Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
deton8 von Splosion
Tom Chichester
Are you a Rotel Televison and Video Expert? Answer questions, earn points and help others
