Check battery charged up ! check connections between battery and starter soilinoid and check the earth clean ! does the soilinoid make a click noise , if so replace it ! check main fuses !
check battery charged up ! check connections between battery and starter soilinoid and check the earth clean ! does the soilinoid make a click noise , if so replace it ! check main fuses !check battery charged up ! check connections between battery and starter soilinoid and check the earth clean ! does the soilinoid make a click noise , if so replace it ! check main fuses !
You can't post conmments that contain an email address.
? 8:03
https://www.youtube.com/watch?v=1L4nB2NdA0U
May 16, 2014 - Uploaded by jimthecarguy
2003 Ford Taurus 3.0 liter 24 valve no start cranks OK.You will not ... Car will not start trouble shooting guide, wont crank, wont turn over, etc.
does it crank fast, at 250 spec RPM?
no year, no joy, all cars have a year,
and and engine option (displacement size???)
my wild guess, is it wont crank or cranks dead slow.
right?
and the battery is DISCHARGED. right,
use jumper start cables. start now?
that be first.
wont crank
cranks perfectly but wont start ?(check for spark, x number of cyl)
spark good, try test fuel
test fuel works for 3seconds and stalls,. then fueling problem , ask.
wont crank or wont start.?? no car starts , if it cant crank. (unless push starter (M/T magic) that is not a trans sensor its the PRN switch. ill answer for, wont CRANK ! it wont crank even with a good battery (charged) or jump started. 1: bad start 2: bad wires to same. so hot wire the starter small wire, the key start line is tiny. cranks. , starter good, no crank starter bad or cables bad. if it cranks hot wired, then the key line is dead. easy, huh?
The crank sensor wires may be oil soaked, try moving them a little and see if it will start. It's beside the crank pulley on the passenger side. Got my lincoln started that way.
explain more............ what kind of plugs, wont crank????? turn over or turn over and wont start, crank no fire???? changing spark plugs wont stop a truck from running.
Not sure what yor experiencing . Do you have crank no start or no crank no start? No crank no start is battery and cables issue. Crank no start is ignition , plugs, and fuel.
