Question about Sharper Image Hybrid GP (SI724) Air Purifier
Hissing
1. Unplug the unit
2. Turn the unit upside down and listen for the beeds to move along the static wires from top to bottom. Turn it upside down again and again until you feel the static wires are cleaned of grime.
3. Plug it in again and see if the hissing is gone.
Posted on Jul 04, 2009
Unplug the unit. Take out the grid. Then turn the unit upside down and listen for the beads to move from one end of the static wire to the end. Do this several times to remove the grime off the wires. Then, check the grid and make sure all the dirt is off the plates. Dry and then insert back into the unit and turn it on. It should only hiss about 20 to 30 seconds while removing the static electricity. This has always worked for me so I hope it works for you.
