I have a downloaded version of HB 13 Check Designer, When I enter data in the voucher section of the check using compatible checks and look at the print preview all the data entered in the voucher section are not align. On my monitor it looks perfectly align. Tried to freeze the objects before printing but like on the print preview, data entered are in the voucher sections will not line up. It only happens on the numbers that are entered, i.e. tax deductions, ss deductions, med employees
SOURCE: print problems
Print to fit page prints thumbnail size image.
Answer
Zoom
out to make your design appear on a single screen, drag and draw a box
around it, using the Select Objects Tool. Once it's all selected, go
to Edit > copy, File > new, Edit > paste. Print from this new file.
Note:
this may be caused by an extraneous object on an outer edge of your
plan. When you zoom out, pan around your design to see if there is a
stray object, which you can delete.
SOURCE: print screen button on microsoft keryboard
Once you are on the screen you want to save, press the PrtScn button once. Now go into Word, Wordperfect, Works, etc. (any word processing program), open a new document, and hold down the Ctrl key and press the V key and it will paste the screen into the document.
SOURCE: MY SIERRA 3d HOME PROGRAM THAT USED TO WORK NOW
Clean the disc, take contact salution or what I do use men's cologn on the disc side and use a lens cloth or a non abrasive cloth to clean the disc and try installing it again. If that doesnt work, check for scratches and that could be the reason it wont install.
DrakeTech
SOURCE: I am trying to print payroll checks from
You have to have the info for routing..etc, entered in both programs.
SOURCE: how may I format 10 labels / page using Avery 8163
right click your printer. go properties. select printimg preferences. select features. find page selections & choose
