Question about Konica Minolta bizhub 350 All-In-One Laser Printer
How do i replace the image transfer beltt on bizhub 350
Norman J Weimar Jr
  • Konica Minolta Master
  • 6,960 Answers
There is no image transfer belt on a Bizhub 350. there is one on a C350?????????????????
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 24, 2016
5 Related Answers
Anonymous
SOURCE: Transfer unit Bizhub C250
reset life of actual transfer
Posted on Feb 14, 2009
Anonymous
  • 12 Answers
SOURCE: Reseting counter after installing new image transfer roller unit
You need to go into tech rep mode to reset.
press: stop 0 0 stop 0 1, then 0 0 0 0 0 0 0 0, press enter, then press counter on the left, select life, then highlight image trans roller and press the C button, repeat for paper dust remover and exit tech rep mode
Posted on Apr 06, 2009
SOURCE: Bizhub C450: After replacing the image transfer roller & ozone
In Service Mode -> Counter -> Life -> Select the one you want to reset and press 'C'
Posted on Aug 23, 2009
just me
  • 60 Answers
SOURCE: how do i replace the image transfer roller unit on
Periodical replacement for IMAGE TRANSFER UNIT is 150,000-print 1. Open the Right Door. 2. Pull down the blue knobs [1&2 ] forward and remove the Transfer Roller [3].
User Copy Operation Handbook page 5-9
Posted on Feb 15, 2011
Ty Schmidt
  • 118 Answers
it is behind the right door but i doesnt need to be replaced you need a pico fuse about
$2 and it can be reset. if yoiu need more help in this and where the fuse is just ask
Posted on Oct 16, 2011
Bizhab c350 c13c8
A new installation is not detected when a new Transfer Cleaner Unit (Image Transfer Belt Unit) is installed.
Did you get some 3rd party transfer belt get a OEM and replace it.
Feb 15, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
C13c8
C13C8 A new installation is not detected when a new Transfer Cleaner Unit (Image Transfer Belt Unit) is installed.
When a new transfer belt unit is installed in a machine an internal component on the transfer belt unit changes state; this now indicates that the transfer belt unit is used
http://kmcopierservice.blogspot.com/2011/02/how-to-reset-transfer-belt-bizhub-c203.html
Apr 10, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
How do i replace the image transfer roller unit on bizhub 350?
Jan 31, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Getting white streaks on black and color horizontally. km bizhub c352p mostly on screens, somewhat on solids.
sounds like you will need to have the transfer belt replaced. all images are developed on the four drums then transfered to the transfer belt then to the paper so if the image problem is coming out on all colors and black an white then the best bet would be to replace the transfer belt
Dec 07, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
I have a Konica Minolta Bizhub C350 which is now indicating that it needs to have the image transfer roller unite and paper dust/ozone filter replaced. Where are these located in the machine and is it...
I would advise having a copier technician replace those items it is not that hard to do but if you dont get the roller seated in the holder properly it can destroy the transfer belt and that could get expensive
Nov 29, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
ERROR CODE C0096 - BIZHUB C350
2.6.19 C0096: Image Transfer Belt pressure/retraction failure
2.6.20 C0098: Fusing Pressure Roller pressure/retraction failure
Relevant Electrical Parts
1st Image Transfer Retraction Position Sensor (PC12)
1st Image Transfer Pressure/Retraction Motor (M11)
Control Board (PWB-MC)
Step Action
WIRING DIAGRAM
Control Signal
Location
(Electrical
Component)
Check the M11 connector for proper connection
and correct as necessary.
2 PC12 I/O check PWB-MC PJ3MC-6B (ON) 6-B
M11 operation check PWB-MC PJ5MC-1~4
(Pulse Output)
6-C
4 Change PWB-MC
Feb 18, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Jan 17, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
