I insert flash drive to show my pictures on slideshow it shows 2 rows of squares with ! marks in them then the pictures. When done playing slide show can't re loop because it sees the two rows of boxes with ! how do I get rid of those?
SOURCE: rolling picture
If your Television is not warrantied, there should be rca, vga, and dvi connections you can use with your pc and video card. Since I am in usa I have know idea what freeview, skybox, or scart are.
SOURCE: Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
SOURCE: The screen shows ''Weak Signal'' and no picture.
Mine did the same thing once. I think all I did was hit the setup on the remote, and let it run back through all the channels and then it worked just fine.
I hope this works for you.
SOURCE: I hook up my tv cable to the Component 1, and it works
make sure you are using component video red green blue cables for video and not just the yellow composite video cable not sure if this helps you but good luck
SOURCE: not all pictures display on my 8'' Innova digital picture frame
I received this as a gift and I have the same problem.
