Question about Haier RWT350AW Top Load Washer, White, 3.0 cu. ft. Super Capacity, Stainless Steel Drum Material, 630 RPM Maximum Spin Speed, Steel Door/Lid, Electronic with Knob Control, Status LEDs, End-of-Cycle Signal, Bleach Dispenser, Fabric Softener Dispenser, Adjus
Pic of drum in washing machine
Is drum the middle piece in washing machine?
Kenmore elite quiet pan 4 he4t plastic piece replacement
There can be a loose bearing between the drum and the outer wall of the machine but, there is definitely something loose. I know that this is not what you would like to hear but, the best advice anyone can give you is have your machine looked at by a specialist. Moreover, going to your washing machine retail store, should have the equipment you are looking for, or you can search for it online and compare prices.
Mar 21, 2014 | Kenmore Elite 45986 Front Load Washer
Thomson washing machine
it all depends if it is a two piece drum that comes apart or a moulded one piece one that'll cost almost as much as a new machine. $400 is rather expensive for a drum bearing fix
Mar 01, 2014 | Washing Machines
Misaligned drum/pulley
realign the pulley to where the belt runs in the middle
Feb 22, 2018 | Washing Machines
Service to repair pcb module hoover optima washing machine
Two screws on the back. Lift the cover off. Pull out dispenser, push middle tab. Pull out. Two screws on the dispenser. 2 screws on the top of the control panel. Take a pic with your cellphone at the wires. Replace and reverse.
Feb 15, 2012 | Washing Machines
HOW DO YOU GET BROKEN LIGHT BULBS OUT OF WASHING MACHINES AND OUT OF CLOTHING?
Wear thick leather gloves to prevent injury to yourself.
Turn off machine - or reset to a short cycle / drain if the door won't open.
Unload with the gloves on into a plastic bucket or basket - take outdoors.
Hang on line dryer for pieces to fall off. If it looks badly ripped - bin the lot.
Hoover when dry if you think it will make it.
Brush up pieces.
Hoover machine drum to clear it.
Wash at least 5 washes without anything in the machine drum - beware of leaks.
Most pieces will pass through into the drain, but you cannot be 100% sure unless the drum is removed and the outer drum and hoses completely cleaned and checked.
If the machine is over 5 years old - buy another one to be safe.
Dec 27, 2010 | Maytag Washing Machines
My maytag washer stopped working during the wash cycle. it made a clicking noise when it happened.. I pulled off the belt it is still in one piece . when i put the maching in spin with the belt off the...
If you turn the transmission pulley one way it will agitate the other it will get hard raise up to release the brake and then turn the transmission and the inner drum. If you cannot turn the drum then I would check to see if a nail has gone through one of the holes in the bottom of the drum or a piece of clothing has jammed between the top of the drum and the top cap of the outer tub.
Nov 01, 2010 | Maytag Performa PAV3200
I have a kenmore front load washer model 41744042400 the drum seems to be off its track. it makes a lot of noise when spinning and shakes a lot. One of the shock absorters was broken and i replaced it....
they dont have tracks they sought of float in the middle of the tub held on by the shaft coming off the spider arm on the back of your drum, if you can move the drum back and forth and it makes a metal crunchy kinda noise your spider arm has snapped to fix it you need a new drum and will almost quite literally have to dissasemble the machine into every piece its made of, altho not neccesarily difficult is quite time cosuming about 3-4 hours (thats for someone with experience)
Sep 20, 2010 | Kenmore Front Load Washer
Our maytag performa top load washer PAV2200 stopped in the middle of wash cycle and we heard a loud pop and then smelled burning rubber. My husband has pulled the belt off the bottom and its still in one...
Check the drain hose from the drum to the pump assembly. Alternativly look for the large capacitor that should be mounted to the internal framwork of the machine, see if has popped. They can make quite a bang when they go,
Jun 20, 2010 | Maytag Performa PAV2200
Zanussi IZ12 bearings gone & plastic fragments in drum
Probably all parts inside drum is ok.Heating element is the only damageable item and a sensor.Changing bearings you must separate the drum, all screws in middle of drum must out and then bearing and zimmerring can be changed.Jan
Feb 15, 2009 | Zanussi IZ12 Front Load Washer
Whirlpool Ultimate Care II drum does not spin.
Depending on your washing machine model, the drum and motor are connected by 2 plastice yellow circular pieces, with a black rubber washer in the middle with holes where the pegs or rods go into. The 2 plastic circular pieces have 3 pegs or rods if you will, that connect to the black rubber washer via 3 holes. Sometimes, one or both of the 2 plastic circular piece pegs get broken off or the rubber washer cracks and breaks apart, so that the motor will not turn the drum. If thats the case, you can purchase the 2 circular pieces and black washer piece as a set.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Haier RWT350AW Top Load Washer, White, 3.0 cu. ft. Super Capacity, Stainless Steel Drum Material, 630 RPM Maximum Spin Speed, Steel Door/Lid, Electronic with Knob Control, Status LEDs, End-of-Cycle Signal, Bleach Dispenser, Fabric Softener Dispenser, Adjus Logo
18 people viewed this question
Top Haier Washing Machines Experts
Marvin
Marvin
Sheldon Dedek
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
