Question about Vacuums
Vax v-060p not powering up
Have changed fuse in plug still no power.
Posted by harryostewar on
Graeme van Malsen
  • 519 Answers
All houshold electrical appliances which are constantly moved about eventually stop working due to fatigue. The most likely cause of your problem is the power cord from the wall outlet.
Replace the power cord then check again to see if it turns on.
Best wishes,
Graemevm
Posted on Jun 06, 2009
Vax stopped mid vacuuming,as though fuse in plug has blown.checked fuse,OK.no lights lit.vax not working.
Most vacuums have thermal protection on the motor that will shut it off if it gets too hot. If you can turn it off, wait 10-15 minutes, and it works when you turn it back on, that's what is going on. Now, the motor shouldn't normally get that hot, so your next challenge is finding out why. Check for any blockages in the air flow or cooling vents, and if the motor also powers something like a beater bar, make certain that it turns relatively freely.
Feb 02, 2016 | Vax Vacuums
My vax power pet 6 keeps cutting out after about 10 seconds, sometimes less. i have changed the filters, theres no blockages, the sunction is great til it cuts out, ive even changed the on/off switch.
I had the same problem, after a few seconds the VAC cut off try turning off the Brush Roll mine then stayed on. the problem is with the rotation brush in the bottom of the VAC you need to take the cap off the end of the brush (the side where you can see the metal pin) it is not easy to get off but it can be removed. if its like mine it will be full of hair, this makes it hard to rotate. once cleaned put the cap back on, put the rotating brush back and it should work. This has resolved my problem.
Jan 13, 2015 | Vax Vacuums
Vax floor steamer is not steaming
First check the fuse in the power point plug, and replace if necessary. If ok, then it is either a loose or disconnected electrical wire, defective on/off switch, or a burnt out heating element.
Aug 26, 2014 | Vacuums
I have a vax mach air u91-ma-b where's the drive
click on the link below and you can dowload the manual witch will give you instructions how to change the belt
http://support.vax.co.uk/power-2-upright
Mar 20, 2013 | Vacuums
Vax rapid ultra brushes not turning
Dear Sir:
1) Test the power cord for defective wires, broker,or loose repair
2) Test the switch for open see the diagram
3) See if there are some open fuse.
4) See if the belt is broken, replace.
5)Test the input voltage motor.
God bless you
May 26, 2012 | VAX Appliances Agilty V123 Upright Wet...
Vax infinity 1900 suddenly stopped working now no power gets to it, i've changed fuse still no power.
I have an infinity nv29 that stopped working while I was vacuuming. According to the manual I was supposed to unplug it for about 45 minutes and then try it again. I waited for over an hour and tried it again and it still won't turn on. Any suggestions?
Feb 06, 2010 | Euro-Pro NV31 Infinity Vacuum
Vacuums Logo
98 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
