Question about Tag Heuer Link Quartz WJ1110.BA0570 Wrist Watch
Adjust bracelet tag heuer searacer - Tag Heuer Link Quartz WJ1110.BA0570 Wrist Watch
5 Related Answers
Anonymous
SOURCE: adjust links on tag heuer watches
They push out. A tool can be bought from Harbor freight
Posted on Jun 14, 2008
Anonymous
SOURCE: Need extra bracelet lings for a Tag Heuer Indy 500
Hi.  I just received the Tag Heuer Indy 500 with steel bracelet today for christmas from my wife.  I'm a smaller man and had to take out 3 links.  I'd never sell this watch so if you would like them...just write. [email protected]
Charles Roscow Silver Spring, MD
Posted on Dec 25, 2008
Anonymous
  • 93 Answers
SOURCE: can tag heuer link bracelet be repaired?
It depends.
First if the Tag watch is older then it cannot be repaired by Tag and Tag won't have any parts for it.
If it is new, Tag should have the parts and a watchmaker or Tag themselves could repair your band. Although I would suggest a watchmaker over Tag if you can find one willing to deal with Tag for the parts. Expect this to take months to get the right link parts.
If it is older then we have repaired some of these with laser welding. Although there is no guarantee as to how long the welds will last, it does seem to work out for a while.
The ones we have done have lasted several years. In fact we just had a customer send his watch back in for a battery and we had welded his Tag clasp back together about 3+ years ago and it is still working just fine.
Hope this helps,
Ken
Yellowstone Watch Inc.
Posted on Oct 05, 2009
Anonymous
  • 61 Answers
SOURCE: how do i remove a link from my Tag Heuer bracelet?
I would have a jewelry professional do this due to the value of the watch. The Carrera pins, however are merely set with tension. It will take a pin pusher or similar thin rod of steel and a hammer. Tapping the pin in the watch will make it come out the other end. Pretty easy really, with the right tools.
Posted on Oct 17, 2009
Anonymous
SOURCE: need instructions for resizing a Link Tag/Heuer Watch bracelet
Hello! I just went through the same thing. If you got the watch new, you can look in the box to find "mini" or "half" links included with the watch. There is no fine adjustment on the Link, but you can replace the larger links with the "mini" links to get the size closer. They are not quite half size, more like 65% of a regular link. So if you add one "mini" link and the watch is too big, you can then replace a regular link with a "mini" link to keep adjusting the size. I went to a dealer (Jared does this, as does Torneau...you talked to the wrong person) and it took about 5 minutes and was $15.
Hope this helps.
Posted on Mar 14, 2010
How do I shorten ******** my Tag Heuer Formula 1 watch?
Take a look at the watch from the side where the band attaches to the buckle. You should see four holes with one of them having a visible pin in it where the band is connected to the buckle. Moving the band to the right will shorten it moving it to the left will make it bigger. To move it simply get something that you can push the pin in with like a paper clip. Push the pin in and the band should come out move it to the left and push the in again and simply move the band into proper position. Once you do that the pin will snap back into place. If that does not adjust it enough go to your local watch store and they can remove links from the bracelet for you. Shouldn't cost you more than $10.
Dec 14, 2013 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Where can i buy replacement links for a tag heuer stainless steel wk1113 watch bracelet
You have to order the links from TAG unless you would happen to see some on EBAY but i would recommend the manufacturer. There are no generic links made for a watch like this! Tag Heuer assistance 1-866-260-0460. I hope this helps you! thank you!
Sep 20, 2011 | Watches
I accidentally stepped on my Tag Heuer TWWK1120.BB0314 bracelet now the clasp doesn't click and lock. Do I need to replace the whole bracelet or just the clasp.
Has it broken, or just been bent out of shape??? If it is just bent you could possibly take it to a TAG repairer or a watch maker to get it adjusted
Mar 25, 2011 | Tag Heuer WK1120.BB0314 Wristwatch
Time & date adjustment
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TAG HEUER watch manuals. Rate me, please.
Mar 31, 2010 | Tag Heuer Monza Calibre 36 Link Automatic...
I require a stainless steel bracelet watch band for a Tag Heuer professional 200 meter
u need to go to a store that carries tag. go to tags web site and find locate store. if they dont stock the bracelet they can order one in. might be pricy
Oct 06, 2009 | Tag Heuer Formula One
II would like to add links to my tag heuer
It sounds like links has been taken out previously. Check the last link ( the one that fits directly into bracelet). There must be a hole and you should be able add links.
Dec 14, 2008 | Tag Heuer 2000 CN1110.BA0337 Wristwatch
Need instructions for resizing a Link Tag/Heuer Watch bracelet
Hope this helps.
Jul 19, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
May 02, 2008 | Tag Heuer F1 Indy 500 CAC111B.BA0850
Adjusting clasp on a Timex watch
Check that clasp from both sides and you should see spring lug ends. Use small pin to get them out(by pushing in). When pin is out you can adjust bracelet.
Good luck
Arthur
Dec 25, 2007 | Tag Heuer 2000 CN1110.BA0337 Wristwatch
My watch dosen't fit
Have a look at bracelet clasp exetnder from RTL Watches
Jul 28, 2007 | Tag Heuer Link CJF2114
Tag Heuer Link Quartz WJ1110.BA0570 Wrist Watch Logo
Top Tag Heuer Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
