Question about Plantronics Explorer 320 Wireless Headset
Can it sync to xbox 360 - Plantronics Explorer 320 Wireless Headset
Mx vs atv alive says activate second controller
I guess it's as easy as pressing A or Start.
But if the controller really isn't connected anyways, you have to:
1: Turn on controller, and hold the sync button ( just to the right of the Left Bumper ).
2: Press the Sync button on the Xbox 360
> Slim version: Sync button is placed just beside the usbports on the front of the xbox.
> Original version: The sync button is placed just beside Memory Slot B ( looks pretty much as the one on the xbox controller.
3: The controller should connect and sync automaticly to your Xbox 360.
Jan 10, 2013 | THQ MX vs ATV Alive for Xbox 360
Were is the sync button on the brand new xbox 360
The sync button on the console is right next to the memory unit b slot on the front of the xbox 360. The sync button on the 360 controller is on the top between the two bumper buttons.
Apr 01, 2011 | Microsoft Xbox 360 Controller
I can't get my remotes to sync with the console.
Connecting a controller to the Xbox 360 is one of those things that should be simple but always ends up confusing and difficult.
Wired is simple; just plug in the controller into a USB slot on the console. It should connect automatically.
For a wireless controller you do the following:
1. Turn on the Xbox 360.
2. Press center Xbox button on 360 controller.
3. Press the small "sync" button on the console.
4. Press the small "sync" button on the controller quickly after step 3.
Of course I never remember the order, so randomly mashing the Xbox button and sync buttons eventually works too. Here's a link to how to sync, but with pictures!
If you're using the Xbox 360 Universal Media remote, I believe it uses an IR (infrared) connection so there is no syncing involved. To use it you just need to point it at the Xbox 360 console (specifically, it's IR receiver). Just make sure the batteries in the remote aren't dead and that the remote is in 360 mode (as opposed to TV mode; just press the "TV" button to toggle modes).
Mar 22, 2011 | Microsoft Xbox 360 Console
I cant get the guitar to sync up with the my 360. it lights up but keeps flashing because it can't connect.
You need to pair the guitar to the Xbox just like you would any other new controller. Press the sync button on the guitar (usually located near the Xbox Guide button) and the sync button on the Xbox (located to the right of the slot for memory unit 2) and they should sync up.
Mar 13, 2011 | Activision Guitar Hero Warriors of Rock...
The white wireless contoller from an older white x box 360 does not connect with the black kinnect x box 360 we just purchased.. i was told they were compatible why doesnt the white controller work with...
There is a sync button next to the Play and Charge port on the controller, all you have to do is press both the sync button on the Xbox and the controller and it should connect. On the nonslim Xbox 360's the sync button is right next to the infared sensor and the memory card slots. On the slim Xbox 360 the sync button will be right next to the usb ports on the front of the Xbox 360 console. When you successfully start the sync the led's for the controller's and console's lights will spin and be ready for you to press the sync button on the other device.
(PS, you have to have both the console and the controller on for this to work; PPS, By controller on I mean having it searching)
Feb 24, 2011 | Microsoft Xbox 360 Controller
MY CONTROLLER WONT CNNCT TO MY XBOX EVEN WEN I SYNC IT . ITS BRAND NEW.
You might have to replace the batteries in the controller, as if the battery life is low the controller will have issues syncing to the xbox 360. Just in cause, To sync the controller to the xbox 360, you must turn on the controller using the xbox guide button and then press the Wireless Sync button right next to the Controller Charging Port. Then you must press the sync button on the xbox 360. You must do this semi-quickly, or the sync process will not complete.
Lastly, You also might have a faulty controller, I suggest you go back to the store you got it from and see if they will replace the faulty controller.
Jan 20, 2011 | Microsoft Xbox 360 Controller
Xbox 360 guitar wont work
That is a syncing Issue, Try this, it may take a few tries. Press the Sync button on the Xbox 360. Then press and Hold the sync button on you Guitar for 1 Second. The Xbox and Guitar Should Sync.
Jan 31, 2010 | Microsoft Guitar Hero: Aerosmith with...
Xbox 360 wireless guitar won't sync with console
seems like the sync problem with XBOX console, you can try fixing this with the help of XBOX 360 repair guide
available here
Jul 14, 2009 | Microsoft Guitar Hero: Aerosmith with...
Guitar hero world tour xbox 360
The guitar syncs the same was a regular controller does.
There's a tiny sync button near the XBox button on the guitar. Press that, and then the sync button on your Console.
Apr 09, 2009 | Buck Guitar Hero World Tour for for Xbox...
How do I disconnect a controller from one xbox 360 and hook it to
press the synce button located on the front of the console. then press and hold the synce button on top the controller. the lights should tell you that the controller has been connected
Dec 01, 2008 | Microsoft Xbox 360 Console
Plantronics Explorer 320 Wireless Headset Logo
Top Plantronics Radio Communications Experts
Harrie
MrFixitSTTL
 Mikey
Mikey
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
