Motorola MC9190-GST Logo
A
Anonymous Posted on Feb 04, 2014
Disable sleep mode
Is there a display setting that will change the delay before going to sleep?
2answers
Macbook air goes to sleep randomly I'm having a macbook air 1466, It goes to sleep mode frequently during work, It's running fine on safe mode Reseted smh pram every thing but the problem as it is
This means that the sensor of the lid is probably damaged or detecting a magnetic field somewhere.
Somewhere on the left edge, if you hold a magnet, you will see the laptop go to sleep. Make sure there is no magnet close there.
You can disable the laptop from going to sleep if it "sees" the lid closing. Make then only sure that you need to let the laptop sleep by yourself.
tip
PC sleep mode problem?
Follow this instructions to disable sleep mode
In windows XP
1)Right-click the desktop, and select "Properties."
2)Click the "Screen Saver" tab, and click the "Power"
button at the bottom.
3)Change the option next to "System Standby" to
"Never" for either "Plugged in" or "Running on
batteries" or both if that is what you want. Click
"Apply," "Okay" and "Okay" once again to close the
Display Properties dialog.
In windows vista
1)Click the "Start" menu, and then click the Control
Panel.
2)Click "System and Maintenance," and then select
"Power Options."
3)Select "High Performance" to disable the overall sleep
mode. The monitor will still go into sleep mode unless
you click "Change Plan Settings" and disable all sleep
options.
In windows 7
1)Click "Start," and then select "Control Panel."
2)Double-click "Power Options."
3)Select "High Performance" under "Additional Plans,"
and then click "Change Plan Settings." Change all of the
options to say "Never."
on Dec 17, 2010 • Computers & Internet
Computer won't come out of sleep
Sleep Mode Problems on a Dell Computer b> When Microsoft patched the power-saving features of Windows XP Service Pack 3 and Windows Vista, certain Dell computers were affected by various issues where the computers would go into sleep mode and be unable to come out of it or error out and not go into sleep mode. Sometimes the computers would go into sleep mode and wake up only when a USB mouse was jostled. Pressing keys on the keyboard would not wake the computer because the keyboard would stop functioning
Open the Dell support page on your Internet browser. See the link Below . http://support.dell.com/ Make sure to have your seven-digit alphanumeric (letters and numbers) service tag. Place that information into the "Choose by Service Tag" option. Make sure that the option for the "Operating System" is correct. Go to "+Bios" and click on the "+" symbol. Click on "Download" at the far right, save and run the downloaded file. Restart your computer after installing the file. Test the "Power-saving" feature once you have rebooted. b> If Section I Does Not Resolve the Issue Go to "Display Properties" by right-clicking in an open area on your desktop and left-clicking on "Properties." Click on the "Settings" tab. Check if the "Display" midway down is saying "Plug and Play Monitor on..." If it is not, go to the "Device Manager." Left-click on the "X" in the top right corner of the "Display Properties" menu. Go to "Start," left-click, and then open the "Control Panel" (or "Settings" and then "Control Panel" depending on your system is set up). Select "System," go to the "Hardware" tab, and left-click on it. Left-click on "Device Manager" about 1/3 of the way down that page. Look at "Monitors" and see a "+" symbol. Left-click on it once and see if it has an exclamation point,"!," with a yellow circle around it. If it does, right-click on the "Plug and Play Monitor" and left-click on "Update Driver." Choose "Yes, this time only" and then left-click on "Next." The wizard will update the monitor drivers automatically, if possible. Restart if necessary once updated. Test the"Sleep" mode again. The computer should go into sleep mode and then wake up successfully. b> If Section I and II Do Not Work Left-click on "Start" and then "Control Panel" (or "Settings" and then "Control Panel," depending on your system's setup). Double-click on "Power Options" to open it. Open the "Hibernate" tab and click on "Enable Hibernate." You may have to reboot again. Test the "Sleep" mode function again. b> Windows Vista Open the Dell support page in your Internet browser. See the link Below. http://support.dell.com/ Make sure to have your seven-digit alphanumeric service tag. Place that information into the "Choose by Service Tag" option. Make sure that the option for the "Operating System" is correct. Go to "+Bios" and click on the "+" symbol. Click on "Download" on the far right. Save and run the downloaded file. Restart the computer after installing the file. Test the "Power-saving" feature once you have rebooted. b> If Section IV Doesn't Work b> Reboot the system and press "F2" or "Del" to get into Bios. Make sure that the "Legacy USB" option is enabled. Save and exit the Bios and start Windows Vista. Go to "Start" and then "Control Panel." "Switch to Classic View" on the left side. Click on "Power Options." Click "Change Plan Settings" and then "Change Advanced Power Settings." Set the "Sleep>Sleep After" to "Never." Set the "Sleep>Allow Hybrid Sleep" to "Never." Set the "Sleep> Hibernate After" to one minute after the monitor and hard drive are set to turn off. Set the "Power" button and "Lid>Start" menu power button" to "Hibernate." Restart the computer and test the "Power Sleep" mode. b> If Section IV and V Do Not Work b> Find the "Windows" sidebar at the bottom right corner. Right-click on it to disable it. Test the "Sleep" mode again. If the computer does go to sleep, enable the "Windows" sidebar by going into the "Control Panel" and enabling it again. Start turning off each gadget one by one, and test the "Sleep" mode to see which gadget is causing the problem. Look at the system and see if you have a "Google" sidebar." If you do have Google sidebar, then pick only one to use, or choose not to use either of them. To remove the "Google" sidebar, left-click on "Start," then left-click on "Control Panel." Double-click on "Programs and Features." Wait for the computer to populate installed software on your computer. Find the "Google" sidebar and remove it by left clicking on it and left click "Uninstall." If you want to remove the "Windows" sidebar, right-click on it, left-click on properties to open "Properties," then remove the check from the "Start Sidebar When Windows Starts," selection and click "OK." Disable Sleep Mode Microsoft Windows 7 uses sleep mode for desktops and laptops to save power during times when the computer is not in use but does not need to be shut down. Sleep mode pauses and suspends your computer until you are ready to continue. In some cases, sleep mode interferes with scheduled tasks or operations such as remote desktop connections. Microsoft allows sleep mode to be turned off and disabled for users that have no need for the function or find that the feature is interfering with their normal computing activities.
Click the "Start" button to expand the Windows "Start" menu. Select "Control" panel in the right column of the "Start" menu and click "System and Security." Click "Power Options" and press the "Change Plan Settings" link next to your computer's currently selected power management plan. Select "Never" from the "Put The Computer to Sleep" drop-down menu. Select "Change Advanced Power Settings" beneath the "Change Settings For The Plan" heading. This launches a "Power Options" panel. Double-click "Sleep" in the menu tree to expand the advanced "Sleep" options. Select "Sleep After" and use the arrow to select "Never." Select this option for both "On Battery" and "Plugged In" if you are configuring power options on a laptop. Click the small "plus" icon next to "Hibernate After" to view hibernation settings. Click the arrow to select "Never." Select "Never" for both "On Battery" and "Plugged In" if you are configuring your power options for a laptop. Click "OK" to close the advanced power options. Select "Save Changes" to save your new power management configuration. Your computer's sleep mode is disabled.
Hope it helps.
If I leave my netbook alone for a few minutes, it freezes and I have to power down and start up again. Why???
It is likely going into a sleep mode.
You can try updating your BIOS to see if this resolves the problem, otherwise you can disable sleep mode from occuring.
I am going to assume you have Windows OS.
- BIOS drivers will be available from the Asus website.
To disable sleep mode:
- Click the battery icon at the bottom right of the screen.
- Select 'More Power Options'
- On either plan, choose 'Change plan settings'.
- Change 'Put Computer to Sleep' to 'Never' for both settings.
Good luck.
2helpful
When the CPU switch on, the system running upto 10 minutes. after that the monitor screen automatically off.
Here is artical I found on how to disable sleep mode on a monitor, this would be for VISTA or 7, if you are using XP it's a bit different. ____________________________________________________________ How to Disable Sleep Mode on a Monitor
Your computer monitor or laptop screen will enter sleep mode after your computer remains idle for a set period of time. You can disable sleep mode if you prefer the screen to remain illuminated. You merely need to change a setting in the Windows Power Management properties box.
Difficulty: Moderately Easy Instructions
  1. Click "Start" and "Control Panel".
  2. Click "System and Security" and "Power Options". This will bring up a new dialog box.
  3. Click the menus to the right of "Turn off the Display" and set them both to "Never". This will disable sleep mode.
Read more: How to Disable Sleep Mode on a Monitor ' eHow.com http://www.ehow.com/how_6953659_disable-sleep-mode-monitor.html#ixzz1CiGFFyLk
1helpful
My hp L1506 going to sleep again and again
In windows XP
"Apply," "Okay" and "Okay" once again to close the Display Properties dialog.
In windows vista
1)Click the "Start" menu, and then click the Control Panel.
2)Click "System and Maintenance," and then select "Power Options."
3)Select "High Performance" to disable the overall sleep mode. The monitor will still go into sleep mode unless you click "Change Plan Settings" and disable all sleep options.
In windows 7
3)Select "High Performance" under "Additional Plans," and then click "Change Plan Settings." Change all of the options to say "Never."
My monitor says going into power save mode and goes off. The computer tower is still powered up and the power light on monitor blinks. when I press the power button on momitor it says monitor working check...
Disable Power Management on Windows 7 or Vista If you are using a desktop computer, chances are that you don’t want the computer to go to sleep automatically. This is even more the case if you are running Windows 7 or Vista in a virtual machine for testing purposes.
Disabling Power Management in Windows 7
Start by clicking on the power icon, and open up the More power options:
sshot-2009-10-21-23-05-42.png Under the “Additional plans” section, select High Performance, then “Change plan settings”:
sshot-2009-10-21-23-06-52.png Then change everything to “Never”, and save the changes:
sshot-2009-10-21-23-07-41.png Disabling Power Management in Vista
Disabling power management is simple and easy. First go to the start menu and click on the Control Panel.
Click on the System and Maintenance link:
vistacontrolpanel%5b1%5d.png Then click on the Power Options link:
poweroptions%5b1%5d.png Then select High Performance:
highperf%5b1%5d.png This will disable the automatic sleep mode, but will still turn off the display. You can click on Change Plan Settings to disable that as well if you want.
Delay in Monitor display once the system goes in sleep mode
Instead of sleep mode, tyr hibernate. It is generally faster except the whole computer shuts down. When you power back up, you're exactly where you were. Mine takes about 30 seconds.
2helpful
3answers
Need help monitor stays in sleep mode... :(
power down, everything, leave it off for a few minutes, turn it back on.. when it gets booted, disable sleep mode option in advanced power features.
Top Motorola Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
